Where do I find this type of "trim" for metal?
I've removed my fog lights, and I'd like to clean up the now exposed openings. My thought is to use a black rubber "trim" around the perimeter (as they are both to remain open for cooling).
I am looking for that rubber "trim" (with metal banding inside) that is used to cover exposed sheet metal so it won't cut or abrade. It is black and is shaped like a "C" so it self-clamps over the edge of the metal. I assume it is sold by the foot. What is it called? Where can I find it? Sorry I don't have a picture. |
how about the stuff used around 911 opening quarter windows, on the body side.
Where do I either? Automotive supply shop? Upholstery shop? Harware store? |
dealer. probably pretty cheap. check it out on a car to see if it will work and if it's long enough.
Mike,
We use some stuff that is a rubber C-channel for panelboards and such (electrical). I could check tomorrow when I get in the office and see if I have any in the feild. You wouldnt need but what, 4' ? Mainly for 16g metal. The other thing you could try is heat shrink tubing. Cut in half and break out the dryer to shrink it on to the metal. Just do it inch by inch so the tubing shrinks around the metal and not on its self. You can find the shrink tube at most Radio shacks and probably Home Depot. They may also have the C-channel barrier. |
I found some on my other car. In the photo it is white (I'd prefer black) and it's used as trim around the sunroof.
http://forums.pelicanparts.com/uploa...1100453443.jpg |
I need it by tomorrow night as my car is on display at a car show on Tuesday. :( Let me see if I can find it locally, and I'll look into the heat shrink tubing too - good idea. If nothing turns up, I'll get back to you. - Mike |
Mike, how about using black door edge guard material ?? Usually has its' own adhesive built in. Cheap and easy to find at your local Autozone type place.
Try this stuff, aircraftspruce is awesome :)
http://www.aircraftspruce.com/catalog/appages/grommetedging.php |
black rubber squirter hose sliced open with a razor will work in a pinch.
www.cleanseal.com has it
Jerry |
reidtool.com, no minimums, lots of good stuff, used them for years.
what you are looking for: http://www.reidtool.com/digitalfiles/Catalog/2004%20Spring%20Catalog/RFF04_85.pdf jason |
| All times are GMT -8. The time now is 04:07 PM. |
