Speed Junkie
Transmission HELP!
Hi all,
Have a couple questions regarding my '89 911 turbo transmission. After my engine build, I will be running close to 500 HP and I need to know what flywheel/clutch disk/pressure plate I should use. Is the factory pressure plate & flywheel sufficient? Or are there components that I can "upgrade" to? Also, I noticed that there is a G50 upgrade/update for 87-89. Is there something I can look at on the transmission to see if this has already be done? (In other words what does the update change on the transimission?) Thanks! |
Where are you at in MI?
I think Nikolas Motorsports would be a good shop to ask about this. Phone: 248.682.7755 No affiliation but they do advertise in our PCA newsletter. Wayne
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Speed Junkie
I'm in Madison Heights. Is Nikolas a local Porsche shop? I didn't think we had any in MI.
Yes they are. They are in Sylvan Lake.
Check out their website. The owner has a bada$$ Turbo himself. If haven't already, you should join the PCA. Great folks with alot of knowledge and connections. Wayne
