help identifying these 2.2L P & C's
all;
2.2L KS (Kolbenschmidt) small pockets cut for valve relief, numbers inside the piston 084071 (over) 1++ also 1275. cylinders are cast iron. are these from a T ? i can post pix if need be. all help greatly appreciated.
best
jerry
Old 02-21-2005, 06:45 PM
If the cylinder fins are cast iron, those are indeed from a T. The E's and S's had aluminum fins with a cast iron sleeve.
Hope this helps,
Jim
Old 02-21-2005, 06:54 PM
