Porsche Junky
mede8er's Avatar
Weltmeister Short Shift....
Well.....before I found out there were still some m241 kits out there I bought the Weltmeister shift kit....I installed it this weekend and can't believe how awesome my car shifts now...replacing the bushings was mandatory also......
That being said....
The biggest problem I encountered was reassembly. The 6mm bolts used for connecting the bushing sleeve were not long enough to 'make'....luckily I had a long 6mm lug on my Pearl drum kit and used it to make connection, then pulled the assembly up and made the connections with the bolts provided........
Just a note to those considering this awesome upgrade......
Old 11-17-2004, 08:14 AM
Rick Lee's Avatar
I'm thinking of doing this soon. Canyou give me the specs on the bolts I should use instead of the ones that come with the kit? Thanks.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 11-17-2004, 08:44 AM
Porsche Junky
mede8er's Avatar
You will ultimately use the bolts provided, but I needed a 4" bolt to get a thread started and pull the assembly up against the tunnel before I could make a thread with them.......
It's a 10 mm bolt as I recall with 6mm thread......
Old 11-17-2004, 09:23 AM
