dj393's Avatar
rear fuse panel cover
Does anyone know what kind/size fastener is used to hold the rear fuse panel cover in place?? I see it has two holes for connectors, but I'm unsure what to use.
Old 11-17-2004, 06:17 AM
Friend of Warren
My '86 Carrera uses two bolts with "wing nut" heads.
Kurt V
Old 11-17-2004, 06:20 AM
Early_S_Man's Avatar
Porsche Crest
Plastic [black Nylon] M6 x 1.00 wing bolts.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-17-2004, 06:37 AM
Designer King
Paulporsche's Avatar
DJ393,
Can you explain to me what you have done w/ your WUR, mixture control unit, exposed hose etc on the right side of your engine?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-17-2004, 09:09 AM
dj393's Avatar
pic
That's not actually a picture of my engine (I wish it was!). Just used it for the picture of the fuse panel cover. Anyone have any idea of the size, and where I can find those wing nuts and bolts(or anything else which might look cool that would fit)??
Old 11-17-2004, 10:28 AM
Friend of Warren
Warren told you the size: the are metric bolts M6 x 1". Any good hardware store will have a selection of metric hardware you can choose from.
Kurt V
Old 11-17-2004, 10:35 AM
According to my factory parts catalog a metal 6 mm "winged screw" (900.029.102.02) and a 6.4 mm metal washer (900.151.003.02) are used. Two of each are required for the cover. Pelican can get then: $1.56 and $1.00 each respectively. Jim
Old 11-17-2004, 11:35 AM
randywebb's Avatar
Agree - mine are not plastic ('73) - imp. if you do concours.
IT's nice to get a new cover and wing bolts if you've just detailed/painted the engine.
And... if you use a CF cover, you'll want some Ti wingnuts....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-17-2004, 11:44 AM
dj393's Avatar
panel
thanks guys for your help!!
Old 11-17-2004, 12:41 PM
I need a new cover, car did not come with one. where can I get a cover?
My 73 911 T targa has a bronze screw bolt that looks like it might fit the top of a cover...
Old 11-17-2004, 03:46 PM
For cover PN see:
Rear Fuse/Relay cover
Old 11-17-2004, 04:03 PM
As to where to get a new cover, I just saw an ad in the new Panorama for one made out of unobtanium (carbon fiber or the like). Only $169. One hundred sixty nine ...
Old 11-17-2004, 05:17 PM
