OCD project capitan
Hello all,
I'm working on a 72 oil tank, and i don't have all the parts at my disposal (or the car for that matter). Anyone who has worked on a 72 oil system, i have a few questions: -How does the tank keep from rubbing against the side of hte sheetmetal? Is there a rubber gromet that attaches to the inner wheel well? -Does the 72 have a different stamped sheet metal inner wheel housing? Or is everything needed for mounting the oil tank just added to the same sheet metal for the '69-'89 year cars? I'm in need of any pictures of 72 oil tank with all the fallowing parts: - The tank complete. -Any gromets that hold the tank from rubbing the side of the wheel well. -The metal strap that holds the tank. -The dip stick. Any help will be much appreciated. Don.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
The tank uses a pair of plastic 'dish' shaped inserts to buffer it from the sheetmetal. They are about 1.75" across.
Not sure about the rest of the issues.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Author of "101 Projects"
It's a wacky setup that is difficult to measure your oil level with! (I've got one)
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
i posted links to some large diagrams in this thread
max |
OCD project capitan
Thanks everyone. Would i assume correctly that the part #20 would be this dish insert? Is it still avalaible?
Item 20 in the above figure is called a spacer in the 72-73 factory parts catalog; it's part number is 91120730700 and three are required per tank. Pelican can order them for you (they're now called a retainer) for $2.00 each. Cheers, Jim
