finished last night, fiberglass, carbs ect. should be a runner on Saturdayhttp://forums.pelicanparts.com/uploa...1101234243.jpg http://forums.pelicanparts.com/uploa...1101234254.jpg
Mark, Since you engine is on the stand can you help with this measurement?
http://forums.pelicanparts.com/porsche-911-technical-forum/193622-fuel-system-dimensions-i-need-height-measurement.html I never get tired of looking at your car. I think I may have to spring for that new fiberglass engine tin and shroud on the next build. |
Mark,
If you need any jetting info, let me know. I can give you the setup I am running. |
Jpnovak 30 centimeters + or - 3 MM
Mark Scott my 2.5 L setup is 155 mains, 55 Idle, idle air 130, airs 180, tubes f16, FBCV'S 50, 4.5 AV'S whats yours? I'll call Richard Parr at pmo and see what he recommends |
Now you've done. There goes the Xmas $$$ on building a new engine. Your killing me Minkoff:)
ITS ALIVE!!
The 2.0L came to life today! Cant wait to break it in at willow on Dec 10. Engine sounds good! Yipeeeeeeeeeee
Oil pressure, no leaks http://forums.pelicanparts.com/uploa...1101616465.jpg http://forums.pelicanparts.com/uploa...1101616493.jpg http://forums.pelicanparts.com/uploa...1101616509.jpg http://forums.pelicanparts.com/uploa...1101616545.jpg http://forums.pelicanparts.com/uploa...1101616569.jpg |
Looks Good Mark.
Redline Gear Oil.... ?????? Motul is what you should use. |
How does it sound???
My keybCVBord keeps shorting oASE$ut because of all tZvnhjhe drool.
Here is the gear oil that Power haus 11 likeshttp://forums.pelicanparts.com/uploa...1101701355.jpg
| All times are GMT -8. The time now is 04:46 PM. |
