LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
OCD project capitan
BigD9146gt's Avatar
Question '72 tank, need some pics of parts
Hello all,
I'm working on a 72 oil tank, and i don't have all the parts at my disposal (or the car for that matter). Anyone who has worked on a 72 oil system, i have a few questions:
-How does the tank keep from rubbing against the side of hte sheetmetal? Is there a rubber gromet that attaches to the inner wheel well?
-Does the 72 have a different stamped sheet metal inner wheel housing? Or is everything needed for mounting the oil tank just added to the same sheet metal for the '69-'89
year cars?
I'm in need of any pictures of 72 oil tank with all the fallowing parts:
- The tank complete.
-Any gromets that hold the tank from rubbing the side of the wheel well.
-The metal strap that holds the tank.
-The dip stick.
Any help will be much appreciated. Don.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 11-19-2004, 02:51 PM
techweenie's Avatar
The tank uses a pair of plastic 'dish' shaped inserts to buffer it from the sheetmetal. They are about 1.75" across.
Not sure about the rest of the issues.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 11-19-2004, 03:12 PM
Old 11-19-2004, 06:25 PM
maxnine11's Avatar
i posted links to some large diagrams in this thread
max
Old 11-19-2004, 08:09 PM
OCD project capitan
BigD9146gt's Avatar
Thanks everyone. Would i assume correctly that the part #20 would be this dish insert? Is it still avalaible?
Don Welch
Old 11-20-2004, 09:27 AM
Item 20 in the above figure is called a spacer in the 72-73 factory parts catalog; it's part number is 91120730700 and three are required per tank. Pelican can order them for you (they're now called a retainer) for $2.00 each. Cheers, Jim
Old 11-20-2004, 10:16 AM
