-   -   To split or not to split (http://forums.pelicanparts.com/porsche-911-technical-forum/193581-split-not-split.html)
PorscheGuy79 11-23-2004 05:03 AM
I am rebuilding the calipers on my SC, should I split them for the rebuild? It says that this may cause them to leak. Whats my best bet guys?
RoninLB 11-23-2004 05:30 AM
the last thing I would do is split them. I split calipers and had no leak afterwards, only an unknown brake problem of constant air in a line or should I say air being sucked into the line.. whatever.
Tim Walsh 11-23-2004 06:14 AM
I've never heard of a good reason to split the calipers and wouldn't recommend it. Just pull the pistons, clean them up and thier bores and put it back together with new seals
RANDY P 11-23-2004 07:35 AM
nope, don't split 'em unless they're leaking already- soak 'em in cleaner for awhile instead. In the rebuild kit there's no rings for the thru bolts.
Superman 11-23-2004 07:40 AM
Nope. Clean, flush, new rubber.
PorscheGuy79 11-23-2004 11:20 AM
Cool, then i wont. What is a good way to get the pistons out without using compressed air? Im young and dont have a compressor.
cbeers 11-23-2004 11:32 AM
I seem to remember reading that someone got them out with a bike pump?
It was a few weeks / month or so I was reading the post in the archives......
-Chris
MotoSook 11-23-2004 11:35 AM
Matt, unless you have cocked a piston or there has been corrosion, you should be able to rotate the pistons while pulling them out. Give yourself a little advantage and push the pistons out a little with with the MC while the calipers are on the car. There is a tech article here that is good. Look in the tech article section.
