To split or not to split
I am rebuilding the calipers on my SC, should I split them for the rebuild? It says that this may cause them to leak. Whats my best bet guys?
Matthew “Sometimes the questions are complicated and the answers are simple.” |
the last thing I would do is split them. I split calipers and had no leak afterwards, only an unknown brake problem of constant air in a line or should I say air being sucked into the line.. whatever.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I've never heard of a good reason to split the calipers and wouldn't recommend it. Just pull the pistons, clean them up and thier bores and put it back together with new seals
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
D idn't E arn I t
nope, don't split 'em unless they're leaking already- soak 'em in cleaner for awhile instead. In the rebuild kit there's no rings for the thru bolts.
In the movies only bad guys sleep in king size beds. |
Senior Member
Nope. Clean, flush, new rubber.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Cool, then i wont. What is a good way to get the pistons out without using compressed air? Im young and dont have a compressor.
I seem to remember reading that someone got them out with a bike pump?
It was a few weeks / month or so I was reading the post in the archives...... -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Somewhere in the Midwest
Matt, unless you have cocked a piston or there has been corrosion, you should be able to rotate the pistons while pulling them out. Give yourself a little advantage and push the pistons out a little with with the MC while the calipers are on the car. There is a tech article here that is good. Look in the tech article section.
