JBO JBO is offline
Fluid change after trans rebuild
Should trans fluid be changed after 500-1,000 miles after a rebuild, as with engine oil after an engine rebuild, or does it not matter for the trans? If it is changed soon for the first time, I'll probably put in Valvoline for the initial fill, then switch to Swepco at the first change.
Old 11-23-2004, 09:04 AM
Early_S_Man's Avatar
Porsche Crest
Yes, by all means ... change the gear oil after 1000 miles, as that is what used to be done at the 1000 mile check at dealers!
Valvoline 85W-140 non-synthetic is what I recommend for breakin.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-23-2004, 10:07 AM
