smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Only starts when key is in RUN position
I've been hunting a problem that I need help on.
I recently got my new rebuild in the car have noticed that my car has the following starting problem. It seems that if you crank the car (START position) it can go all day long and not fire up. Only when the key is released (RUN position) does it actually fire up.
Anyone know where I should start to de-bug this problem.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 11-23-2004, 01:02 PM
Who is John Galt?
Rondinone's Avatar
The fuel pump cut out relay is bypassed during cranking so that the fuel pump runs even though the air sensor plate is still grounding the relay. The relay is bypassed by sending current from the start wire (yellow) into the normally open side of the fuel pump relay. A poor connection at the relay or a bad relay can cause your problem. I would put a voltmeter on the fuel pump and see if it's getting voltage during cranking.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 11-23-2004, 01:28 PM
smestas's Avatar
Thanks for the reply Rondinone.
I'll give it a look and report back.
"viva la alusil" Your brother in the alusil revolution.
Simon Mestas
'78SC Coupe
Old 11-23-2004, 03:30 PM
it could be the ignition switch. see if you get 12V to the red wire in the plug on the CD unit while cranking.
206 637 4071
Old 11-23-2004, 03:39 PM
white87911's Avatar
smestas, is your ignition system stock?
"Coffee is for Closers"
"Push the button Max!!!"
smestas's Avatar
@ white87911 - Yes it is all stock the best as I can tell.
@ JW - I'll check the CD also.
Also as a side note I have removed my rev-limiter because it was causing the fuel relay (red relay) to pulsate when connected to the point where the red relay would get hot. Since I disconnected the limiter the pulsing relay has gone away. The problem with the starting existed prior to the removal of the limiter. Not sure if the problem is realted but I thought I'd mention it.
Simon Mestas
'78SC Coupe
Old 11-23-2004, 03:49 PM
Send a message via Yahoo to Lukesportsman
If you have a stock ign switch this mimics a past problem of mine exactly.
John's answer is best if you have someone to help. If not here is what I did: I simply ran an auxillary wire to the ignition and verified it would start if I had power to it. If it starts fine with a flick of a switch then your ignition switch is probably dead.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 11-23-2004, 03:51 PM
smestas's Avatar
Well I tested it today and I only get 12v to the red CD wire while the key is in the RUN position and it drops to 0v when cranking.
Does this mean my starter switch is bad?
Simon Mestas
'78SC Coupe
Old 11-28-2004, 03:37 PM
kinda sounds like it. you can pull the plug off your original one without removing it from the dash, and then attach a new or borrowed switch to the plug for test purposes. use a screwdriver to start it. most shops have a few lying around.
206 637 4071
Old 11-28-2004, 03:44 PM
smestas's Avatar
Thanks John!
As always I owe you another case of beer.
Simon Mestas
'78SC Coupe
Old 11-28-2004, 03:55 PM
smestas's Avatar
Well I bought a used switch from another member here on the board (he said it was working). Unfortunatly I still have the same results (no 12v to the red CD wire durring cranking). Can I possibly have two bad switches? Is there another way to test if a switch is good or bad? Im kind of lost on all of this so any help is appreciated.
Simon Mestas
'78SC Coupe
Old 12-05-2004, 04:32 PM
the red CD wire gets power from the top of fuse 11, which is bridged to fuse 12, which gets 15 (key on) power from the ignition switch. red/black is the 15 wire. does the 15 wire loose power when the switch is in start mode? check at the switch first, then if that's ok, at the top of fuse 12. the other red wire at the top of fuse 11 goes to the fuel pump relay and on to the over-rev cut-off relay that disables the fuel pump relay on over-rev. it's separate from the red wire circuit to the CD unit.
206 637 4071
Old 12-05-2004, 05:10 PM
smestas's Avatar
Thanks for the help John but Im afraid I dont know which is fuse 11 and 12. I also dont see any of the fuses to be bridged. Are you refering to these two fuses in the fuse block?
Simon Mestas
'78SC Coupe
Old 12-05-2004, 06:23 PM
the bridging is done inside the back of the fuse boards, except for that one below the red relay. count from the front. it looks like there has been some wire swapping there, so who knows if it's correct. you're looking for a red/black wire in the vicinity of the two fuses you circled, at the top of one of the fuses, that gets hot with the key on. when it gets hot, it also makes a red one next to it hot, via the bridge, which goes to the CD unit. you can also test the red/black wire off the back of the ignition switch. i assume you have a test light. to find the red wire up by the fuse board, attach a test light to the CD plug and jump power to the suspected red wire, which if correct, will light the test light. you can also jump it to get the car started of course.
206 637 4071
Old 12-05-2004, 08:14 PM
smestas's Avatar
JW,
You were right about some of the wires being swaped. I finally located the correct wires and found that there was no bridge between the two. After further hunting I found a unconnected wire comming from the top of the red/wht fuse. After hooking everything up it works perfectly!!!!!
A happy ending to a long ugly story.
Thanks John and all others who replied to my cry for help.
Simon Mestas
'78SC Coupe
Old 12-07-2004, 01:47 AM
