What is that "rotary dial thing" on my fuel line?
Hi,
I got this sitting right between the fuel filter and the carbs of my 69T. I have no idea what it is...it is currently set to position 2...why not? Should it be set another position? Thanks for the help. PS: I am currently rebuilding my interior (have to be done by Turkey day...promised my wife...) and will post pics and history then.
ZeFreds 1969 911T - Daily driver "La Titine" Bought on the following condition from my wife "Do NOT let it sleep in the garage...you have to drive it EVERYDAY!"...I love my wife! |
Fuel pressure regulator? Should be set to 5psi I think, but if you don't have a guage.......
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
cheapo fuel pressure regulator. 3# is good for webers.
Thanks guys!
I will change the setting during lunch break! The next best thing after owning a Porsche...is the Logging to the Pelican BBS! (The whole thing being ranked after my wife and son, of course)
Unregistered
When you change the fuel pressure your float level will change, it is a good idea to set the pressure and then check the float bowl level.
Some people adjust the level by making changes in the pressure, not a good thing. |
Last thoughts on this
- Can this affect gas-mileage? It is not an issue, but 15mpg seems a lot, and not right. I am an engineer, and like to have things right.
- Can it affect iddle? Thanks again.
Thanks sammyg2. So this is probably not a good idea to do that during lunch break...
Super Moderator
Hey,
THe numbers on the dial do NOT necessarily indicate the resulting fuel pressure, as they were generic. The result pressure depends on the input pressure and depending on what fuel pump you have, could vary. Also and MOST IMPORTANTLY, there are a number of instances of FAILURE and FIRE documented with this type of cheap regulator. Please get a quality regulator fast.
Fire...ain't my plan! That is a good tip! Opening the check book right now...
I'd replace that unit with a higher quality one and add a pressure gauge. I researched pressure regulators when I was doing carbs and was advised that the one you have pictured is not dependable, leaks, fires etc. I went with a Holley regulator and gauge. Works very well.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
PMO has a nice one with a built in P gage.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
You do not have permissi
I got the Holley and guage, but the pressure will change unexpectedly: set at 3.5lbs and an hour later it's 1 to 7. I'd recommed the PMO.
Meanwhile other things are still happening. |
....or just get a pump that outputs 3-4 psi. No FPR needed. I use a pump manufactured by Airtex. The system works just fine w/o a regulator.
Sherwood |
Holley has a good reputation, not perfect, but good. Alot of VW guys run them. |
My first holley pressure guage was faulty. Was showing very low presuure and was not responsive to changes in the regulator setting. I returned it and the second one worked like a champ. It is possible that they suffer from poor quality control. I have a very well built older pressure gauge that I was using as a reference unit.
what was the model # of the regulator you installed? Just checked their web site and there are a number of models available...
Holley parts
c911s,
If you are asking about the Holley parts, i'll have to go out to the garage or to their website to answer properly. It's been too long. Here is a pic to tide you over. Not a great pic, but maybe you can identify from the pic and website. P.S Zefreds: I don't mean to hijack, but i think the original question was answered and spawned additional questions.
Holley Fuel pressure regulator - Low Pressure 1-4PSI
P/N 12-803 Fuel pressure guage is the 15 psi, liquid filled P/N 26-504 or equiv.
Re: Holley parts
Well said. |
NO apologies...the more question asked...the more we learn...
