jmz jmz is online now
jmz's Avatar
searching for air-scoop for cooler/brakes
Does anyone make an air scoop to replace the missing light on this front pic.
I've seen the ones that fit further outboard but for some reason just don't care for them.
Thanks in Advance,
Jay
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 11-24-2004, 09:10 AM
Bill Verburg's Avatar
That would be a DIY item
Bill Verburg
Old 11-24-2004, 12:07 PM
I've posted here several times trying to get the side marker lights re-configured to work as turn-signl lights....maybe even move the T/S over to the side as shown....to allow direct coolong air to hit the oil cooler.
Is that what you've done? Still visible from front?
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-27-2004, 06:56 AM
jmz's Avatar
Yup, I wired the outboard lights to work as turn-signals. It worked well enough that it passed the safety inspection.
JZ
Old 11-27-2004, 08:03 AM
Designer King
Paulporsche's Avatar
Jay,
How about removing the guts from the former turn signal housing, opening up the back, fastening some expanded metal screen to the face of it, and putting it back in place? This is what I did to my fog lamp housing to create an inlet. Sorry I don't have a pic for you.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-27-2004, 09:37 AM
jmz's Avatar
Paul, that sounds a whole lot easier than fabbing up something out of fiberglass or sheet metal.
Thanks for the idea, I'll give it a try and post pics when/if I get it done.
Jay
Old 11-27-2004, 09:41 AM
Designer King
Good luck. I'm assuming it was a fairly straightforward wire swap to get the side markers to blink. Do they still come on solid @ night and then flash for the turn, or do they stay off and then flash when needed (like normal for turn signals)? What are you doing w/ the passenger's side? Do you have a cooler there too?
Paul
Old 11-27-2004, 09:52 AM
