Help.... how do I get the seat out?
I am trying to get the roll cage out of my '87 Carrera. I thought I was going to be able to unbolt the seat, slide it forward and get it out, but the seat is going to have to be out of the car.
I got the front and rear seat bolts out of the passenger seat with no problem, but I cannot figure out how to disconnect the electrical connection. I thought it would be a simple plug, but it appears the wire is going into some sort of a little black plastic box. Any suggestions would be greatly appreciated since I have this thing all apart now Thanks, rickdm:confused: |
Assuming you have the partial power seats like mine (2 switches for seat height), after the bolts are out, just tip the entire seat back and you'll see the seat-switch wires go into a black box..which is the plug/connector. I just pulled that plug apart. It's a 4 prong plug and should uncouple easily. If that connector isn't there, maybe someone modified your seat wiring?
Thanks Steve. When I flipped the seat over I could see the connector plug and it came right out.
Thanks, rickdm |
| All times are GMT -8. The time now is 01:42 PM. |
