-   -   Increasing performance of 1978sc! (http://forums.pelicanparts.com/porsche-911-technical-forum/194071-increasing-performance-1978sc.html)
crashmy911 11-26-2004 02:25 PM
i' would like to increase the performance of my sc. At the moment it has 964cams 8000rpms valve springs and pre 74 exhaust. How can I get this car to pull better from low rpms and put me back in my seat? Also when I rebuilt the engine it has mahle pistons and cylinders so what would my compression be with this engine?
Vipergrün 11-26-2004 02:31 PM
Have you tried advancing your timing and richening the fuel mixture? It would be wise to know your CR, though, so you don't have detonation issues...
-B
crashmy911 11-26-2004 02:34 PM
timming is set at 35 degrees at 6000 rpms per John Walkers advise. She runs good but not alot of low end torque.
crashmy911 11-26-2004 02:35 PM
Mixture is set at 3.5% can this be set alittle bit richer?
crashmy911 11-26-2004 02:49 PM
Will going to carbs really make that much of a difference. the car is just a car used for fun.
Lothar 11-26-2004 02:52 PM
I don't believe that the 964 cams are known for low end torque. They would have moved the torque curve more toward the top end.
crashmy911 11-26-2004 03:00 PM
Once engine is reved up it pulls nicely but you have to have the rpms up all the time or there is nothing.
dd74 11-26-2004 03:05 PM
Depends. Carbs (Webers) react best to more radical cams than 964s and different pistons than what sounds like CIS pistons that you've put in your engine. To really make use of carbs - not that you can't now - but to their highest ability, you need to tear apart your motor and put new pistons in, not to mentione open up the heads some, and maybe modify the fuel pump.
If you're wishing for more low-end torque, you may as well go back to SC cams. I have an '83 SC engine with '74 heat exchangers, and it has good torque from as low as 2,500.
If you want a more radical cam than the 964, go with the WebCam 20/21. You might get power up to 7,000 RPM with the 20/21, and since you have 8,000 RPM valve springs, well...
crashmy911 11-26-2004 03:30 PM
So what do I need to do to have a really radical engine go to higher commpression more radical cams and carbs. Should I go to dual plugs also. What kind of difference will I see and will I have to fudge with it all the time to get it to run right. Or is it a set and go thing?
dd74 11-26-2004 03:46 PM
You need to get "Porsche 911 Engines," authored by the Mojo Jo-Jo of this forum. He has a very nice section on different flavors of modified 911 engines. Then, you need to decide which types of mods you like (webers, supercharging, turbo, short-stroking, etc.), then pose many questions to the board. Get oodles of money together, but before you spend, make sure you do not already have enough power. To do this, you should take your car to your nearest race track and make an honest assessment if your current setup is enough for you.
nostatic 11-26-2004 03:50 PM
buy a Mustang.
PSRacing 11-26-2004 04:50 PM
Good advice, you need to know how you want to use your car, how much power you want, and how much you want to spend.
I have had very good results with SC’s by using SSI heat exchanges dull outlet, Dansk Sport Muffler w/ dull inlet and 4” outlet, Porting and Polishing heads, Polishing intake runners, Enlarge throttle body, Ignition timing @ 35 degrees @ 6000 RPM then if I have detonation I back off the timing until it is gone.
You already have the better F.I. w/ large intake runners. I would do the bolt on items before tearing your engine down again, to save expense and incase you find the power that you are searching for.
Doug
fintstone 11-26-2004 05:30 PM
I have a Supertec built '78 engine with webcam 20/21 cams, SSIs, ported heads (39 intake, 38 exhaust) and 9.3:1 compression JE pistons. It accelerates very well throughout the rpm range, but my car is probably quite a bit lighter than yours. Less weight is often easier than more hp. Gearing/tire size also makes a big difference.
If your rebuild used the mahle pistons/cylinders that were stock for '78, your compression is 8.5:1 . Stock port size for '78 is 39 intake, 35 exhaust. If you know who built your engine, call and ask them for a copy of the build sheet.
chuckw951 11-26-2004 05:34 PM
"put me back in my seat"
Could be a tall order!
I'm running a 1982 SC motor with 9.3 to 1 compression, 40mm PMO carbs and SSI exhaust. The motor also has the HPX ignition with allows you to change the ignition curve easily. I'm running stock pistons and cams so I'm not getting the most from the carbs. If I were to go for more power I would change the pistons and cams and maybe open up the intake ports. I suppose I could twin plug and run more compression. Or add larger P&Cs to make a short stroke 3.2. I'm not sure when 46mm carbs are needed on a modified 3.0-3.2. I know when I built my motor 40mm carbs were recommended. But all of these things get expensive quick, and in my case I'm committed to using carbs as I made that big purchase.
I think you have a couple of options, and as others have stated, it depends on what you would like to do with the car.
If the motor was rebuilt with stock 78-79 P&Cs you could be running a 8.5 to 1 compressions ratio. In 1980 porsche bumped up the compression ratio to 9.3 to 1 (but for some reason used small intake runners and intake ports). But who knows and beyond opening up the motor I'm not sure how you can tell. Perhaps consult with the shop that did the motor? Perhaps the cylinders have part numbers that you could read and cross reference?
There are a number of threads on the 911 engine rebuilding forum (and this forum) about modifying a 3.0 for more power.
Couple of ideas:
1. Give up on motor modifications and focus on the suspension or making the car lighter.
2. Build a 3.2 short stroke motor by adding bigger P&Cs.
3. Carbs, cams, heads, pistons (and perhaps twin plug, even higher compression)
4. EFI instead of carbs with the mods in #3
5. 3.2 or 3.6 swap
6. Sell the car and buy something faster like a 930 or install your motor into a light early 911.
7. supercharge
My friend Jim is running a supercharger on his 79 SC. Lots of low end power.
Here is a pic:
http://forums.pelicanparts.com/uploa...1080422871.jpg
rdane 11-26-2004 05:35 PM
Re: Increasing performance of 1978sc!
Cams, exhaust and muffler is pretty much it for cheap power in a CIS 3.0. Torque is even more expensive. High compression pistons or a big bore is the next step up in price. You have the best heads for power (78/79), the worst for torque. The later SC and the the 3.2 Carrera were all redesigned 3.0s to specifically give you even more torque.
Bottom line? More torque lower in the rev range on a 3.0 isn't going to happen.
964 and 20/21 cam will be hitting the torque curve flat at 4000 and drop off again by 5200/5000 max. Peak HP will be between 6300 and 6700 and dropping off sharply at 6700 or earlier.
There is nothing left in an SC engine to use the HD valve springs with. (althought their is some protection on a over rev or misshift) Your (and mine as well) engine is "all done" at 6500rpm.
I have a couple of dozen dynos on different CIS 3.0s that say the same thing.
SC-964-20/21 Cams and CIS are the limitations.
The answer to low end torque is more displacemnent. My 3.4 CIS has more torque now @ 2500rpm than my 3.0 had at peak. My peak torque rivals the 3.6 engines in performance for comparable cars.
The 3.0 was 168rwt @ 5500rpm and now it is 175rwt @ a lowly 2500rpm. (that is not a misprint) It means 2nd gear starts are now about what 1st was!
A recently dynoed 964 3.6 with exhaust and a performance chip was 216.3 max torque at the wheels..
My 3.0 to 3.4 CIS conversion is now 213.3 max torque. It hits 210 at 3800rpm and stays to 5200rpm.
More torque really means you want a bigger engine. None of them are cheap, 3.4/3.5/3.6.
My base engine was a '79 3.0 now a 3.4 CIS. 20/21 cam, SSI and a sport muffler and 9.8:1 single plug. Most recent Dynojet dyno @ 260 hp and 250 ft/lb of torque calculated with a 15% loss.
This is the first dyno at 1000 miles
219 rwhp=258 crank @ 6100rpm with a 15% loss
213 rwt= 251 crank @ 4100 with a 15% loss
http://standingwave.org/albums/porsche/amp.sized.jpg
http://standingwave.org/albums/porsche/akz.sized.jpg
cvfncrew 11-26-2004 06:03 PM
Put your car on a DIET. :D
Don Dosmann 11-26-2004 06:13 PM
I have a 78' SC with 964 cams, ssi's with Super traps, and 9.5:1 JE's. When I built this engine I noticed all the low end torque was gone, because of the 964 cams, but it really came on stong above 4K. Because of being rearended and the engine catching fire, I had to rebuild the engine induction system and electrical systems. I decided to build a Mega-Squirt EFI system (that has been well documented elsewhere on this board). The Mega-Squirt system works well, all the low end torque is back and than some. The torque is flat from idle to redline, though the engine is running a little on the rich side. I mostly track this car and dropped my lap times at Elkhart Lake from 2:55 down to 2:43 this passed July. It's fun passing 944 turbo's out of corner 14 and out pulling them down the front straight. I built my own system and have about $750 in the whole system. A really good bang for the buck.
Don
rdane 11-26-2004 06:16 PM
Dropping weight and/or lower gears /gearing will change your perception of the car and change its performance. Neither of those changes will give you more low end torque from a 3.0.
For a quick glance @ some 3.0 dyno numbers look here.
http://quelle911.com/phpBB2/viewforum.php?f=6&sid=ebc1ee9ad05409f3808993800a7f 49d2
Not a natually aspirated CIS 3.0 car out there that actually "pulls" past 65/6700 or has anything (>150lb.) below 3000 for torque. Trust the dyno numbers and not your butt.
Engine management systems like Electromotive/Motec/ Megasquirt will add to the low end torque but it won't be much.
Single plug 3.0 9.:1 compression cars with a performance cam and SSIs will typically give you 195 hp at the wheels and 175# of torque.
Same 3.0 engine with the factory CIS 8.5:1 pistons same a performance cam and SSIs will be 180/5hp and the same 175#s of Torque.
Here is a '79 CIS SC with SSIs, a 2/2 Dansk and a 20/21 web cam
and 190,00 miles on the unopened engine.
http://www.standingwave.org/albums/p.../agg.sized.jpg
rdane 11-26-2004 06:51 PM
I agree Noah, but you still have to keep the revs @ 3.5K or better to do that in a 3.0.
I "own" my share of 3.6s in all flavors ;) 4K is the magic number in my car but 3K will work just fine as well. You just have to hold on till 7K. The last 500 rpm to 7K is just good measure for the next shift. It isn't makeing more power no matter how much faster it goes. And it does go.
But them today I got a good lesson on what a 2.2 S engine is capable of, driven with some skill. He was running 6 to 7000rpm all morning! Sounded awesome! It was also very quick.
crashmy911 11-26-2004 07:35 PM
Noak Pollacks articles.
You are the reason I went with the modifications that I have made to this car. I had broken studs and had to do something and cams and valve springs were two areas that where cheap to do. After doing this the car is fun and fast butI would just like to make faster and perform better lower in the rpm range. Hell to pull away from suv's and mini vans in this thing you have to really run it. Don't get me wrong either it is still a fast car I just wish you could get some level of performance with out hammering it.
rdane 11-26-2004 08:07 PM
Noah's article is where everyone starts. Good stuff.
911s are made to run at high rpms. The race cars need something like 7 to 9K!
My build list and some earlier comments that hopefiully will help to put it all into perspective.
Originally posted by rdane
Here is what I used. Costs can go past 15K$ or be less than 10K depending on what you are starting with for a 3.0.
Great engine as is...amazing really. I would not do it again on a CIS 3.0, unless I was starting with a decent 3.0 with SSIs and hopefully a good performance cam.
What most forget is all the street flat 6s will cost the same to build basically, if new cranks, P&Cs and rods are part of your needs. At that point look around for options. IMO having done it and beat the 3.6 transplant costs by a good deal with similar performance I would look for a 3.2 Motronic and start there for a 3.4 or bigger engine.
Also the Max Moritz P&C is specifically designed for single plug and 93 octane gas.
The cost of case work, P&Cs, rods and cranks become trivial in the long run for a street engine that will last well over 100K miles, so plan well.
My '79 CIS 3.0 to 3.4 has the following at 258hp and 251# of torque.
3.2 crank
Puater rods and bolts
Mahle 98 P&Cs @ 9.8 for a 3.364
SFL Piston skirts, Ceramic coat on the Pistons
EBS valve spring
TI retainers
APR case studs
New injectors
new exhaust valves (which is why I tore the engine down)
boat tail the crank cases and half moon the cylinders
Bored throttle body
match and polish the intakes
20/21 webcams
SSI
sport muffler
light flywheel
sachs power clutch
(I used Jon @ EBS for the majority of Mahle and other engine parts)
Twin plugs? I didn't do them but I did the machining so they could be added at a later date. I also live at sea level and in a mild climate with 93 octane gas available. (At 8K miles I can say I am not disappointed in a single plug)
Skip the older dual plug stuff and do Electromotive twin plugs. It is good insurance on bad gas and cheaper to install. Twin plus are insurance to keep your engine in one piece. Problem you'll have is deciding where to stop with case work, twin plugs, induction, cams, compression ect. My budget was $15K and I beat that by $1500 even with extras like the coatings, case work, injectors and throttle body and got a great engine.
My start point was big as it gets, street gas, single plug and no case work. That defined the 98 P&Cs, 74.4 crank for 3.4, and 9.8:1 compression.
But I also had a great engine going into it with a new clutch, flywheel, cams and SSIs which is not part of that budget number.
If I had not already done all those I would not have started my 3.4 CIS project. I could do a better (read 3.4 or bigger) Motronic for less.
nostatic 11-26-2004 09:03 PM
Re: Noak Pollacks articles.
Like I said, get a Mustang.
If you want to win streetlight drag races and don't want to live in high revs (I can't understand either of those, but to each their own), there is no replacement for displacement.
As for me, I love running these cars in the 4-6K range. Who cares about the first hundred feet or so....once you get up there and keep it there, there is plenty of fun. But, to each their own...
rdane 11-26-2004 10:12 PM
From an earlier thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/130188-reseda-dyno-day-results.html
(DD74) has a stock SC motor in his 1974 911. His only mods so far are early (74) exhaust and a Triad dual-in-dual-out muffler. With a car as light as he's made his, the slightly-better-than-SC numbers are going to make it really scoot:
http://forums.pelicanparts.com/uploa...1069583618.jpg
Do a search under Tom's screen name emcon5. He has done a bunch of really good comparison graphs for cams and the 3.0/3.2s.
try http://forums.pelicanparts.com/showthread.php?s=&threadid=163860&perpage=10&pagen umber=5
and
http://forums.pelicanparts.com/showthread.php?s=&threadid=168088&perpage=10&highl ight=20/21&pagenumber=3
Originally posted by emcon5
Updated.
http://forums.pelicanparts.com/uploa...1085171279.gif
What I would really like to have is a graph for an otherwise stock early SC with backdated exhaust.
Tom
edit: fix chart
dd74 11-26-2004 10:17 PM
Yes, it's a beautiful thing. SmileWavy
rdane 11-26-2004 10:48 PM
Worth noting the better torque curves aren't really a matter of CIS adaptable cams in 3.0s it is the different valve sizes in the early and late SC heads. That is shown in the torque curve comparison chart. (trust the torque curve shapes more than the numbers)
More HP can be found in the bigger ports of the early heads, more torque in the later, smaller heads.
That trend was followed through to the Carrera's 3.2.
As many have mentioned 4000 to 6000 rpm is where the 3.0s come alive. Nothing is going to change that short of ditching the CIS and the CIS appropriate cams. You can get more power with a hot cam and carbs but your rev range will be higher and power in an even more narrow band.
If you really want torque talk to the guys on board who have the 3.6s or the guy who owns a Z06;).
dd74 11-26-2004 11:13 PM
RDane - In an Excellence magazine from this summer, Bruce Anderson finally seemed to conclude that the 2R runners (smaller) were more appropriate for the 3.0 engine in stock form than the larger 4R runners which were on the 78-79 3.0s.
rdane 11-26-2004 11:23 PM
David, guess it depends on what you find "appropriate". Porsche thought the hp was a good idea over low end torque in the race cars. When the American market kept complaining about the high reving engines Porsches shipped with, first they enlarged the engines from 2.2 to a 3.0. Then when even that didn't make folks happy they made the ports smaller to get more low end torque out of the 3.0. Americans were still looking for a V8's torque....more displacement and smaller ports again on the 3.2...which gave more torque.
Torque has always been behind building a bigger flat 6. HP is just a measure of torque, right?
crashmy911 11-27-2004 02:58 PM
I will try thing with the throttle body and see if it is opening fully tommorrow. If my car is in say third gear and I'm driving along at 2500 rpms should I be able to stand on it and go like mad or would it be better to down shift it and floor it. I have found that If I'm not running the car fast it doesn't like when I stand on the gas unless the rpms are already high say 3700 or up. the car dosn't even like to go up hills unless the rpms are above say 3000. With other sports cars I have had. You could drive along at 2500 rpms and not have a problem going over inclines. With this car it will complain alittle bit and even lug if I try and do this.
nostatic 11-27-2004 03:14 PM
A 911 is not "another sports car". But you sure you're not talking about a muscle car as opposed to a sports car? For instance a Honda S2000 doesn't really get cranking until well over 6 or 7K.
Try keeping your revs between 4-6K. Shift to keep it there. If it means 3rd gear on the freeway, so be it. If you stomp on it, it will go. But it will never feel like low-rev-torque-happy 'merkun iron.
anthony 11-27-2004 03:14 PM
At 2500 rpms in third, if you want to it to go, you better downshift to second.
>>You could drive along at 2500 rpms and not have a problem going >>over inclines.
Were those V8s? 2500 rpms is barely a blip off idle for these cars.
H20911 11-27-2004 03:44 PM
After skimming this thread and reading the same advice that is given all the time it seems (all good advice though)
I have to say.
1) gear it lower and stay in the upper rpm range
2) 3.6 conversion with Mods
3) get a mustang (good advice already given)
4) get a big block GTO, Chevelle, GS, Cuda ......etc.
5) ride in a V8 converted 911 and see what you think.
because as the advice given might imply your can't get there (Torque) from here with a N/A 6 with out $$$$$$. then you will have a high strung engine that will push (but not pin) you back in the seat.
I'd go 3.6 with mods and the diet if you want to stay with in the p family.
dd74 11-27-2004 03:46 PM
...With other sports cars I have had. You could drive along at 2500 rpms and not have a problem going over inclines. With this car it will complain alittle bit and even lug if I try and do this.
This, I think, is the reason so many people swap in larger engines, such as 3.6s, when the real nature of the 911 engine is not necessarily low-end torque, but high-revs.
This could also be, on a more technical level, why Webers have been said to only be good with 911 motors if they are track cars. CIS and Motronic are much better suited for all-around driving.
crashmy911 11-27-2004 05:29 PM
Don't get me wrong about the car. I love it and I love how it revs and comes on the cam. neat stuff. Just wanted to see if I could make it better down low. Maybe as I become a better driver I will push it harder and not be afraid to be carrying so much speed into corners and out. So it could be me. I wish or maybe would be wiser to drive at slower speeds accelerating out of corners waiting to see if it slides at slower speeds and still be able to correct. I'm just scared to be at the speeds I'm at when diving spiritedly. Second just wish I could do them at lower speeds and allow the sliding and mistakes to happen at much slower speeds to learn how to correct. When ever I'm at the slower speeds I would need to be in first to get the power I need and we all know that first isn't somewhere you want to be when downshifting and pushing the car the way I want to.
fintstone 11-27-2004 06:04 PM
Sounds to me that what you really need is a little DE.
asphaltgambler 11-27-2004 06:28 PM
Rdane: was that reading in rear wheel HP /TQ??
nostatic 11-27-2004 07:45 PM
what flint said. Sounds like the last thing you need is more hp/torque. Instead, get to know your car in a proper environment. You'd be amazed what a stock SC can do...
masraum 11-27-2004 08:49 PM
You need a DE and or some AutoX experience. If you want to experience things at lower speeds then find a deserted parking lot the next time it rains and experiment there.
You don't need more power, you need more experience and confidence or if the drive for more low end torque is that important then you need a different car. These cars/engines are built more like a highly strung racing engine than a regular car engine, and so they need to be revved. The more you do in the way of cams, free flowing exhaust, free flowing intakes, you are just making the engine build more power at higher RPMs. The odds of you building a 911 engine that will put you back in your seat at 1500 rpm and hold you there until 7 or 8000 rpm are not very good.
It sounds like you aren't in the right gear when you are coming out of a corner. Try downshifting. You probably want to have the engine at 3500-4000 or even 4000-5000 when coming out of a corner to feel the pull.
crashmy911 11-28-2004 01:23 PM
I guess where I get to drive the car spiritedly is on back country roads that you wouldn't be going all that fast. What happens I want to down shift inot first and that scares me with the 915. So what happens I'm in second and that isn't low enough. So maybe I just need lower gears in third forth and fifth. Hell I never use fifth unless i'm going over 100 miles an hour!
masraum 11-28-2004 03:11 PM
Hmm, must be some really tight twisties to not be going at least 35 or so. You wait for 100 to go to 5th? Wow, I was in 5th at 70 if I was cruising on the highway.
rdane 11-28-2004 03:29 PM
No big deal, we all have had steep learning curves with these cars. Best bet is a PCA DE. That will answer a wealth of questions very quickly.
