irl irl is online now
irl's Avatar
Send a message via AIM to irl
How do I take dust caps off.
I have an easy question, how do I take off the bearing dust caps without banging or tearing them up.
Old 06-02-2004, 10:26 AM
goat's Avatar
Believe it or not I used a small ball hammer and tapped around the edges and it works itself right off, and no dents. I think wrenches ect. would really tear it up.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 06-02-2004, 10:31 AM
Automotive Monomaniac
Emission's Avatar
Mine had little threaded nipples on the tops. I put a bolt in there and mechanically backed them out.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-02-2004, 10:33 AM
The 930's are threaded because the hubs are deeper. Here's how I used to do it before I converted to 930 brakes:
Old 06-02-2004, 10:37 AM
alf alf is offline
alf's Avatar
Tap it with a wood or plastic mallet, should come right off. Tim is right, wrenches would most marr them.
alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 06-02-2004, 10:39 AM
put a 2" exhaust clamp in the groove and then pry on the clamp.
Old 06-02-2004, 10:44 AM
This is another one of those threads that keeps coming back like, well, one of those threads.
Maybe when someone first signs up on the board, they get emailed a FAQ containing links to dust caps, E-Rams, 'which oil is best' and stuff like that.
Old 06-02-2004, 10:46 AM
irl's Avatar
Thanks all, sorry for the JV question.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 06-02-2004, 10:49 AM
Emission's Avatar
Don't apologize. Good question (but... found in the archives ).
Old 06-02-2004, 11:37 AM
Irrationally exuberant
ChrisBennet's Avatar
I tap around the cap and it "walks" right out. I use an 8" piece of 2x4 applied to the cap and tap the other end with a big hammer.
Avoid using a metallic hammer on the cap itself - it's very easy to hit a stud that way and wreck the threads.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-02-2004, 11:49 AM
Emission's Avatar
Threaded caps for the Turbo, FYI.
They were not that easy to get off!
Old 06-02-2004, 12:00 PM
MBruns for President
JeremyD's Avatar
Two hammers with claws. Stick the claws from one hammer under the lip of the dust cap. Strike the head with the head of the other hammer. Work yourself around until it starts coming off. I have found that this does not mar the dust cap - And mine were on tight tight tight!
Old 06-02-2004, 12:08 PM
cary's Avatar
Originally posted by widebody911
This is another one of those threads that keeps coming back like, well, one of those threads. Maybe when someone first signs up on the board, they get emailed a FAQ containing links to dust caps, E-Rams, 'which oil is best' and stuff like that.
Thom, I was thinking the same thing.
Everytime I see one of those posts. It makes me chuckle. Should add a how to use the search function with that FAQ starter e-mail. I would save some of the new folks from getting blasted.
irl, don't take offense. Just part of getting your feet wet. I still think the dust cap removal is the #1 first question.
You'll be chuckling too, in a couple years.
Good Luck
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 06-02-2004, 04:46 PM
cary's Avatar
Oh yeah, my .02c.
BIG A** CHANNEL LOCKS
Cary
73 914S 2.0 AG
Old 06-02-2004, 04:48 PM
joecrum's Avatar
It's SOOOO easy, just "gently pry off bearing cap" as instructed in Bently. Yea, right. I had to use channel locks, like pictured above, and tapped the channel locks with a ball peen hammer. I don't think it was ever removed previously. Mine's a little scratched up now, but it did come off.
Good luck!
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 06-03-2004, 10:01 AM
irl's Avatar
Thanks for all the suggestions, and I will use the search function next time. I think I have found the best solution myself. A small pair of welding C clamps attaches very nicely and does not scratch or ding the cap. They just wiggled off with some effort. Hopefully you do not have to own a pair of these, but if you do, they work awesome. Thanks again
79 SC unmolested
25 GTS
Old 06-03-2004, 10:15 AM
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Aloha - it took me some time to find the search function. Maybe the letters could be bigger, or it could be moved to the top of the page? I find it most useful now that I have found it.
Cheers,
Mike
(very junior member)
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 06-03-2004, 10:22 AM
I know of a case where we broke a slide hammer (!) and the d%mn thing still didn't come off a turbo ( the one with the threaded center) !!!!
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-03-2004, 10:38 AM
And a pair of safety glasses
I got yelled at big time for doing this.
Old 06-03-2004, 11:32 AM
You do not have permissi
john70t's Avatar
With a little concentrated heat at the interference lip while turning the hub it should lossen up a little more.
Or bounce the suspension with the channel locks lol. Either will work. Just go slow and even.
Old 06-03-2004, 04:56 PM
