-   -   Need HPX ignition settings help (http://forums.pelicanparts.com/porsche-911-technical-forum/194540-need-hpx-ignition-settings-help.html)
hars914 11-30-2004 04:25 AM
I just installed a electromotive HPX crank fire ignition on my 69'
911 'E' motor which is stock except for 40 webers and headers.
Since I never ran one of these kits what are the best settings?
The instructions call for 12 degrees initial,24 degrees @ 3000
and -2 degrees at 8000. Are these settings OK for this motor.
This will only be run on the street.
cstreit 11-30-2004 06:04 AM
You can initially mimic your stock advance curve, however Richard Clewett claims that engines with the higher 3k RPM advance show more torque. I have a 3.0L but it's twin plugged and I use 8, +21, and +2. However a single plug motor will have more advance.
I think 12 is still a bit high for initial settings despite what EM says.
304065 11-30-2004 08:59 AM
I don't understand the nomenclature evidently.
The idle timing for my '71 2.2 E is 4 ATDC. The advance at 6000 RPM is 35 BTDC.
Are you fellas describing some points on a curve or something?
chuckw951 11-30-2004 10:55 AM
Here is another thread to review (re: settings for HPX on a 3.0)
http://forums.pelicanparts.com/porsche-911-technical-forum/144077-settings-electromotive-hpx-ignition.html
