Hey all.
Within the last week, the starter on my daily ride, a 1988 Carrera, makes an odd "zzzt" the instant the engine lights. It seems, maybe, the cooler weather here in San Diego is not allowing the Bendix to disengage as quickly as it should. The cold engine starts instantly on first tap and all other starts during the day are without the sound. It's just that first one when it's stone cold. Thanks for any personal pointers. (update: the Bendix got worse, but changing out the starter cured the problem.)
- Bob Last edited by Bob Prosser; 07-15-2008 at 02:08 PM.. |
Designer King
Bob,
I had a thread on this about 3 or 4 weeks ago. The zzzzz apparently was the Bendrix drive not totally engaging/disengaging . You should get this fixed before you ruin the flywheel teeth. Others have said that they cleaned their contacts and the unit worked as before. In my case I had it replaced since it had 172000 mi on it. It can be done w/o dropping the engine.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Thanks Paul.
I did a search, but I couldn't see it. Can you give me the thread's title? And when you did the job, would you have rather pulled the engine? I was thinking of paying someone familiar with 3.2s here in San Diego to pull it in his shop, then I'd give it a nice once over. Best, Bob
- Bob Last edited by Bob Prosser; 11-30-2004 at 02:03 PM.. |
Hey, my '88 has done the same thing on occasion...had no idea what was causing it.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Is this Paul's thread?
1984 Targa |
Thank you Scott. Much appreciated.
- Bob |
