jfw834's Avatar
Send a message via AIM to jfw834 Send a message via Skype™ to jfw834
Angry stupid periscope headlamp washers!
well, after installing and lining up a new pair of H4s, i managed to create TWO annoying problems within about 2 minutes. first, when screwing back in the the screw that holds the headlamp ring in place, my hand just gently tapped the periscope washer unit and broke it off!
THEN, if that wasn't stupid enough...i knew i would have to replace that, so i wanted to test the washer system to see if it worked or not (to merit upgrading to the flush squirters) and after a few attempts i hear some trickling and yup, i burst some line or hopefully something just came loose, but about a gallon of windshield washer fluid started spewing out by my front AC condenser!!
is this something that is easy enough to fix myself? should i replace both nozzels with the smaller ones? (since the other one might break off in the future)
and most inportantly, does anyone know what the usual cause of a blockage in the system is? the motor winds up and definitely provides preasure since it most likely blew a hose off it's connecter. could it be clogged nozzels? arg this is so annying cause i don't even CARE about headlamp washers....who needs those in california anyways!! i would take them off and throw them away, but then i would have giant holes in my bumper.
p.s. my windshield washers don't work either...
__jfw834__
'90 C2 Cab - '12 Challenger RT
"A woman is only a woman, but a car is an A-U-T-O-M-O-B-I-L-E!"
Old 11-29-2004, 07:53 PM
AFJuvat's Avatar
You probably cracked a line at the washer pump
(BTW, thats an AC condensor, not an oil cooler)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-29-2004, 08:13 PM
das908kind's Avatar
Send a message via AIM to das908kind
The DIY repair world is a slippery slope, as I'm discovering. Beware.
Old 11-29-2004, 08:14 PM
jfw834's Avatar
AFJuvat
thats exactly what i meant....AC condenser...
__jfw834__
Old 11-29-2004, 08:16 PM
Detached Member
Hugh R's Avatar
You can buy the headlight and windshield washer check valves (they get clogged) from Pelican. Their purpose is to hold fluid in the lines so that you don't have to wait a long time for fluid
Hugh
Old 11-29-2004, 08:38 PM
Gordo2's Avatar
Headlight Washer Replacement Tips
Both of mine were broken off when I bought my car. A necessary evil to replace.
Some tips I wrote up:
PITA Job 2 (Cont): Headlight Sprayer Repare Tips
Once I replaced them and had the system working I found that they get spray all over the hood and fenders in addition to the headlights. Nothing like accidentally hitting them just after cleaning the car, water spots all over the place.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 11-29-2004, 08:58 PM
jfw834's Avatar
well i think you guys are right...here is what i found under the hood...looks like this was and L check valve and it blew open. If this one blew open, does that mean that up to there, the other T valves should be ok? there is quite a mess of rubber tubes down there. also which way is the fluid flowing? out of the big one into the smaller one??
also...i found this rubber clip sitting underneath the hose busted hose...anyone know what it's purpose was?
__jfw834__
Old 11-29-2004, 09:19 PM
That rubber band is to hold the jack.
The large tube comes from the high pressure pump.
I don't think that periscope is broken, rather the clip is missing.
If you upgrade to flush washers, I'd love to get your periscopes. I kid you not.
Old 11-29-2004, 09:28 PM
jfw834's Avatar
thanks for the info....are you about the periscope? the part looks broken on the underside of the squirter to me. I will check again....do they come apart normally at that point?....
__jfw834__
Old 11-29-2004, 09:37 PM
jfw834's Avatar
here is a pic of the underside of the nozzle. there is a sharp uneven edge that it has broken on, from what i can see.
__jfw834__
Old 11-29-2004, 09:55 PM
jfw
you're right, that one is broken. Didn't pay attention.
They are IMO one of the smaller very defining mid-70's details of the 911. One of the few details that survived the lightweight plan on my own car.
I wonder. looking again at the picture of the tubing with the broken plastic inside your trunk, if the large bore tube you hold in your hand comes from the hi-press pump itself (on the right of the windshield washer pump in the pic)? That would mean the hi-press pump has a broken fitting.
Old 11-30-2004, 02:05 AM
jfw834's Avatar
Tristan,
you have no idea....those headlamp washers are such a important and integral part of....of....uhh....ok i guess i'm just a loser
however, thanks to those that want to buy my periscopes, but does anyone know HOW to get at these things to reinstall?? i want to do it myself and will probably order the smaller ones. If anyone wants to buy the periscopes, i will sell them, and the broken one you could probably superglue back together....possibly.
__jfw834__
Old 11-30-2004, 07:31 PM
jfw,
there are clips that hold the washer on the bumper. You can access them from underneath if you are flexible, or else remove the bumper.
Seeing from your pics, a complete assessment and repair/replacement seems in order, as quite a few parts seem to be broken.
And YES they are an integral part of the 70's 911
Old 12-01-2004, 01:00 AM
