Zenith carb plug sealing?
It's rebuild time and the plugs that cover the transition ports appear to be sealed via some white substance on the thread rather than a washer. This would explain why they were v. tight to undo. When rebuilding has anyone replaced this white sustance? What is it? Any recommendations for alternatives you can get down your local motor factor?
See piccy below for the plug in question....
Thanks for any advice!
Gary
Old 12-02-2004, 02:32 PM
I would rather be driving
jpnovak's Avatar
Looks like corrosion to me. There should be a copper sealing ring.
Old 12-02-2004, 03:06 PM
al lkosmal's Avatar
Like Jamie said, there should be a copper sealing ring, but someone may have used some type of sealant as a substitute. They are included in the rebuild kits if that's the direction your headed. Nit sure if they're available seperately.
RGruppe #669
http://www.x-faktory.com/
Old 12-02-2004, 03:35 PM
Thanks for the replies, I've got a full rebuild kit so I'll check for any spare sealing rings.
Ta
Gary
Old 12-03-2004, 01:58 AM
