LjH LjH is offline
LjH's Avatar
3.2 Idle tips
Like many of us my 86 Carrera cab was cursed with a 2000 RPM idle. After much research I decided to start by replacing the bushings on the bell-crank that bolts to the transmission (915).
First: lift the car as high as you can. This makes it easier.
Second: The cotter pin is inserted from the back and is spread and bent back tight to the shaft. Get a small flat head screwdriver and pry it up to get leverage.
Third: The rod going forward is a very tight fit. It is as least as tight as the gas pedal fit so be careful because, unlike the gas pedal, the level on the bell-crank will bend easily.
Fourth: The other end of the bell-crank it held by two 10mm nuts. Remove it.
Fifth: Once the two rods have been disconnected and the cotter pin has been removed REMOVE THE ROD from the transmission.Then clean things up, insert the bushings and reassembly.
Old 02-27-2013, 11:44 AM
Member 911 Anonymous
DRACO A5OG's Avatar
did it work? there are bushings on top of the engine too
'85 Carrera Targa
PCA/POC
Old 02-27-2013, 01:41 PM
LjH LjH is offline
LjH's Avatar
Thanks for asking. So far so good. Took it for a shot test drive, idle drops like it should and CC works. A pretty good day after all
Old 02-27-2013, 01:46 PM
DRACO A5OG's Avatar
Congrats!
'85 Carrera Targa
PCA/POC
Old 02-27-2013, 02:00 PM
