Quick question, Bench test a starter?
I think the starter is shot on my 69 project. I have it out of the car and in the vise on the bench. When I hook the batery directly to the solonoid via the jumper cables still nothing. My only real question is the correct way to hook up the jumper cables when trying this. Can anybody help?
Non Compos Mentis
My local auto parts store will test starters for free.
When the starter failed on my '88, I pulled it out and replaced with the hi-torque unit. Out of curiosity, I "tested" the old one on the bench with a battery, and it seemed to work fine (on the bench with no load). So I'm not sure that bench testing like you mention will really tell you much. At any rate, there were three leads - ground, battery +12v, and trigger +12V on the '88 starter. Hope that halps somewhat.
993 |
Senior Member
Positive cable from the battery to the large lug on the solenoid.
Negative cable from the battery to the case of the starter. Take a small jumper wire from the positive lug on the solenoid and touch it to the "trigger" connection (the small spade termial on the solenoid) and please be ready to hold it to the bench when you do this as it should move around a bit if it does work. Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Friend of Warren
What Joe says.
Kurt V No more Porsches, but a revolving number of motorcycles. |
