Alternator wiring ???
AFter seeing the post about wiring for a race car, I got thinking about my no-charging issue in my SC. The car is a 78, the engine is a 74 2.7. Should I have an external voltage regulator for my alternator on the 2.7? Does anyone have a pic of one so I know what the heck to look for? Thanks.
Andrew Gruppe B #055 78 911SC 74 914 2.0 02 C230K Kompressor 73 VW Beetle AutoStick 02 F250 4X4 (Parts Hauler) 03 Kia Sorento (Wife's DD) |
Bump
I believe the 2.7s and early SCs had external VRs. It should be on the left side of the engine compartment under the plastic cover. In 81 or 82 the VR was attached to the underside of the alternator. Look under the plastic cover first, it's a small, silver boxy looking thing.
Kurt |
I would rather be driving
HMM I guess my post never showed up.
Both the engine and the car should have an external voltage regulator. The difference may be in the wiring. The 74 had all wires carried through the 14pn connector and the 78 had a separate loom attached to the engine harness. Only the blue excitor wire went through the 14 pin connector. The VR will be on the rear console. It is usually in teh upper right corner just left of the CD. It will have a 3 pin plug in teh bottom with a brown, black and double blue wire on a single post. These three wires go to the back of the alt. and a single blue wire going forward to the dash light.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
double post. the first was lost in server tie up...
disband
it mentions the difference in the bently regarding the switch for the 80 sc.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
