911sc Rs!!?
Hey Guys,
Was wandering around the 'net today when I stumbled on info regarding the 1984 911SC RS. Seems Porsche was able to blow a 3.0L up to 250HP. I'm wondering if this is feasible using my stock 3.0L as a starting point, how much it would cost, and whether it would be usable as a semi-daily driver. Any thoughts? |
Re: 911sc Rs!!?
Keith 1979 930 2007 WRX wagon |
In a word, no. It will not make a good daily driver as it will be too peaky. Build a 3.2 instead.
Or if your empahsis is heavily on the 'semi' part then yes. but the 3.2 heads will still flow a lot better. Start counting out the $10,000 bills now for your budget.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 12-04-2004 at 06:14 PM.. |
they used MFI instead of CIS, the older RS airbox/intake, and thats all i know for sure.. someone else can chime in for the rest
if you do a search, you'll find a number of threads on the SCRS. It wouldn't be cheap to build (mostly the engine...the bodywork isn't that whack), but you'd have a pretty unique "clone".
The SC/RS had a Bosch-Kugelfischer plunger injection pump instead of a K-jetronic one, the compression was raised from 9.8 to 10.3 with forged pistonsans the cams had 12.1mm valve lift on intake and 10.5mm on the exhaust. With a road legal exhaust the engine put out about 255hp @ 7,000 but only 188lb/ft of torque. You would be better off with a larger displacement engine, because the lack of torque and peakiness would make the car pretty abominable on the street. Plus, sourcing the proper parts would be a nightmare.
80 911SC Coupe, Grand Prix White- 3.2l twin plugged,Electromotive EFI w 46mm PMO throttle bodies, Fabspeed RSR headers/exhaust. 305whp. |
