Somatic Negative Optimist
Gunter's Avatar
Question WD-40 opinion: Positive or negative?
My many years experience with WD-40 have been positive. It is a light lubricant, does not harm electrical, or rubber, or plastic. It dissipates over time leaving no hard or sticky residue and is a mild penetrating oil.
The King of Tacoma, rdane , who keeps the economy around Puget Sound alive by completely overhauling his beautiful 911 every year, says otherwise. I value his opinion but want to hear more voices. What say yee?
WD-40 goot / nix goot?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-05-2004, 09:34 AM
Send a message via AIM to tkrefeld
There is better stuff ..PB blaster comes to mind
Old 12-05-2004, 09:35 AM
Gunter's Avatar
WD-40 was never designed, or promoted, as a penetrating oil, just a light lubricant. If I need to open a stubbern rusty nut, I would use PB Blaster, ot Moove-it, or similar penetrating fluids.
Old 12-05-2004, 09:42 AM
Agreed....and Boeshield T-9 is what you want for corrosion protection of metal and electrical..It just rocks!!
Old 12-05-2004, 09:46 AM
Irrationally exuberant
ChrisBennet's Avatar
WD = Water Displacement
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-05-2004, 09:50 AM
PCA7GGR's Avatar
WD = Water Disapater - I believe it goes back to WWII.
A brake through back them, but there are better, more specialized products available today. At this year's SEMA, for example, the makers of PB Plaster had close to a dozen other spray products thhat were designed for various applications/uses. There were also a multitude of other firms with alternatives.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 12-05-2004, 09:54 AM
competentone's Avatar
The "WD" stands for "Water Displacing" -- I find it useful in that application, and to clean greasy/oily things. I regularly use it for cleaning guns, motor parts, lubricating building's doors and locks, and most any application where a light lubricant is needed.
I've heard people claim that it's horrible, but have never heard any argument from them that justifies their opinion. Most of their poor opinion is the result of them trying to use it in a way it wasn't designed to be used or is completely unrelated to any "failure" of the product itself.
Old 12-05-2004, 09:58 AM
hkspwrsche's Avatar
Ive read for years (even when I was a little kid reading skate board magazines) that wd-40 breaks down the grease that keeps the bearings/wear surfaces lubed...Works to free up or clean and even spray inside a damp distbutor cap..but, not to be used in the place of grease or lubricant..
Harold
Old 12-05-2004, 10:33 AM
WD-40 turns to "goo" in time; it is preservative not a lubricant or penetrating oil. Jim
Old 12-05-2004, 10:53 AM
I winterized a lot of small boat dizzys with it.. otherwise it's at the bottom of the food chain imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-05-2004, 10:59 AM
rdane's Avatar
The main ingredient of WD-40 is kerosene. It isn't a lube...decent cleaner for something you'll then wipe down and lube with something else.
Ever seen what happens to kerosene if you leave it out long enough?
I use a lot of wd-40 in my shop on a daily basis but only as an economical metal cleaner.
..Issaquah... Gunter not Tacoma More like bonded servant than king.
No way I would get wd-40 anywhere near a working CIS system. I might use it to clean some of the parts of a CIS system but then I'd wipe it down with a good lube before I put it back together. Better safe than sorry. CIS has enough problems as is.
Old 12-05-2004, 11:09 AM
randywebb's Avatar
Jim - do you have advice on various lubes, corrosion protections, etc.? Maybe you can list a task category and then what you think is a (commonly available) chemical for that task.
FIW - you can now buy single cans of Kroil at various mailorder places - ti doesn't have the smell that pbBlaster has.
Then there is the Corrosion Block discussion re Mg trans. recently.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-05-2004, 11:13 AM
good toolbox cleaner.
206 637 4071
Old 12-05-2004, 11:42 AM
Unregistered
sammyg2's Avatar
it is a last resort, so many better products out there.
Old 12-05-2004, 11:44 AM
removes grease and tape residue well. also fun to use as a mini blowtorch when you're about 12 years old.
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 12-05-2004, 11:45 AM
tkrefeld, how do you use Boeshield? I use it on all my woodworking equip. Do you wipe it off or do you let it sit and dry. I leave a thick film. Thanks, jeff
Old 12-05-2004, 02:32 PM
I spray it on the engine and elctricla and just leave it..It leave s clear layer that seems to work excellent...I do find that if you spray it on something that is likely to get quite dirty it will escalate that...
Old 12-05-2004, 02:36 PM
I don't use it - not sure what it does or what I would use it for!
Old 12-05-2004, 02:38 PM
A Quiet Boom's Avatar
Makes a great cutting fluid for aluminum on a mill or lathe. On the lathe with WD-40 I can get near polished looking finsh cuts. Other than that I use it to prevent rust on tools.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 12-05-2004, 03:00 PM
Am I the only one that thinks a WD40 thread is funny, I mean, I've been drinking a few and leaving for dinner in a few minutes, but WD40? are you serious? I'm not trying to be a dick, just find it rather amusing, pointless, in a good way
Diesel/Kerosene in a spray bottle works very well
Old 12-05-2004, 03:30 PM
