86 911's Avatar
Send a message via AIM to 86 911
Rain capturing devices in a Turbo Tail
I would like to know if there are any rain capturing devices that I could use in my Turbo Tail so that the rain would not get into the distributor or spark plug area. A month ago I left my 911 in the rain, and the distributor got wet, and it would not start! Right now, my tail has the wire netting and a "rain tray". The "rain tray" covers half of the engine, and the netting is right under the "ribs" on the tail. Is everyone else's similair or the same? If the 911 ever does stay in the rain, I cover the engine with a tarp.
Here's a photo:
Thanks,
Matt
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 12-05-2004, 08:56 PM
Where is the "rain tray" in the picture? I see the wire netting, but no kind of rain tray.
(P.S. The painter of that car needs a friendly introduction to this great new product . . . called "masking tape"!)
Old 12-05-2004, 09:26 PM
86 911's Avatar
The "rain tray" is not visible from the bottom, although if you look from top down, you will notice that half of the engine lid is covered and looks like a scoop where rain would go when it runs down from the top of the lid. It probably isn't a "rain tray", but part of the engine lid. It looks like it could be a protectant for half of the engine though.
I agree! Actually, he left masking tape still hanging from the underside creavas of the hood! . In some spots, the paint even leaves dripping formations. The painter never really cleaned the car off that well either since the paint is cracking and peeling in some areas. It is also bubbling from the weld of the turbo look fenders in the back. I'll probably get a "quality" re-paint in a couple of years.
Thanks,
Matt
Matt
'71 VW Bus
Old 12-05-2004, 10:24 PM
Your motor should be able to get wet and still start. You must have some sort of ign. problem. You should look at your wires and all connections.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-06-2004, 04:51 AM
v9ff's Avatar
Dean
I agree... I had a Strosek style tail on my 911 for years which was my daily driver and it didn't even have a grille cover at all! Yep! Basically, two open holes about 12X8" on the top of the tail. The 911 always started up even in the rain.
Old 12-06-2004, 06:01 AM
Friend of Warren
What the others said. You have a distributor cap problem.
Kurt V
Old 12-06-2004, 06:06 AM
86 911's Avatar
Thanks for the suggestions. I think it might be a problem with the coil now that the car is stubborn and will not start. (See "Perma Tune CD box" thread). I'll probably re-seal the distributor though.
It's good to know that the engine can withstand the rain.
Thanks for the help .
Matt
Matt
'71 VW Bus
Old 12-06-2004, 09:36 PM
