Changing Flasher
What is the failure mode of the turn signal flasher. My turn signals stopped working, and they don't even statically light up the turn lights. The flashers don't work either.
From my manual, it looks like the flasher is buried behind the left side of the dash, and I need to pry out the instruments to get to it. Is this true?
Phil
89 930 Slate Grey/Black
K27 B+B 1 Bar
shaved gutters
backdated to opening vent windows
Old 12-05-2004, 06:51 PM
Send a message via AIM to fintstone
If both turn signals and emergency flashers don't work...it is most likely the flasher. It is approximately behind your far left gauge when sitting in the car. I find it easiest to reach through the front luggage compartment. It is on the far right (driver's side) behind the fiberboard piece. If you do a search, I have posted in the past how to test this with a multimeter or test light. They are expensive...if you can...borrow a buddies and swap it in to test it before you buy one.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-05-2004, 10:57 PM
