-   -   What are "Solid timing chain tensioners"? (http://forums.pelicanparts.com/porsche-911-technical-forum/195519-what-solid-timing-chain-tensioners.html)
H.G.P. 12-05-2004 11:37 PM
I have not seen these advertised much? Are these widely used?
Thank you.
svandamme 12-06-2004 01:47 AM
never heard of that term , maybe they mean the racing mechanical variant , i had those in my engine when i bought it :
right
http://forums.pelicanparts.com/uploa...1102326354.jpg
left one compared to the hydraulic one i just installed
http://forums.pelicanparts.com/uploa...1102326406.jpg
alex jelepis 12-06-2004 09:36 AM
solid tensioner
Wayne's rebuild and performance book suggests using them temporarily during re-builds, but I have seen them advertised as Bullit Tensoners for e permanent use as well.
How do you adjust the tension once they are fitted? Is there a screw which increases the tensioner as you turn onto the idler arm?
Alex
H.G.P. 12-06-2004 09:36 AM
I did a search on tensioners and they came up. I'll see if I can find the link.
chuckw951 12-06-2004 09:41 AM
Stomkiracing sells them for $65/pair
http://www.stomskiracing.com/products.html
http://www.stomskiracing.com/Images/sr011.jpg
Email Steven, stomracing@aol.com, he can tell you about them if your search through the forum doesn't help.
cstreit 12-06-2004 09:41 AM
It's a manual adjust. Some people use them in racing motors permanently, but they need to be adjusted often, and the motor has to be good and warm before you go anywhere so the engine expansion takes up the slack.
H.G.P. 12-06-2004 09:43 AM
They are list here down the page:
http://www.mpdonline.com/porsche.htm#Solid%20Timing%20Chain%20Tensioners
Grady Clay 12-06-2004 10:07 AM
This is probably one from the early ‘70s.
I use it when adjusting cam timing.
http://forums.pelicanparts.com/uploa...1102355892.jpg
Solid tensioners are OK for race engines where you replace
the chains, sprockets and jack shaft regularly.
For normal use they are a no-fail alternative but
unnecessarily stress and wear the valve train drive parts.
There is a tool that measures chain tension.
I’ll see if I can find the info.
Best,
Grady
H.G.P. 12-07-2004 09:10 PM
Best,
Grady
After dismanteling the chain housing/tensioners/housing parts, I could see visible areas where the chains ran into the housing (stretched chains? bad tensioners?).
Why would a solid tensioner stress and wear the valve train?
Thanks!
svandamme 12-08-2004 04:48 AM
Thanks!
they don't move... so if the engine changes dimensions ( hot - cold ) it doesn't change with it like spring or hydraulic tensioners do...
so you either have a chain that is to tight or to loose , depending on your engine temp...
alex jelepis 12-08-2004 10:36 AM
tensioner tool
Grady,
Any luck finding out about the tool for measuring early tensioner tension?
Thanks,
Alex
H.G.P. 12-08-2004 09:27 PM
What about in-between?
And how does one know if a "regular" tensioner isn't adjusting under normal instances? ( The tensioner is never seen while driving)
svandamme 12-09-2004 09:04 AM
if you set it inbetween , then it will be off for both temps , but just right for a half warmed up engined
a regular tensioner will apply a certain pressure to the chain
it doesn't matter how hot or cold the engine is , the pressure will be similar .. more or less
the solid one , doesn't apply pressure at all, it's just set to a certain location, and that location will usually be in the way of the chain , causing a pressure... but if the chain is stretching ( heat or old age ) then the solid tensioner isn't doing anything to counter it
i think the logical way is to say a solid tensioner does not make the tension , its the chain that tensions around the tensioner
( i know , this is crappy tech terminology )
while a spring or hydraulic tensioner , tensions the chain , if the chain changes then the tensioner will tension more
the hydraulic tensioner has an even bigger advantage, because it has both a spring ... and oil pressure , the higher the more revs, the more pressure , the more the tensioner tensions the chain
i don't think the problem is setting it for hot or cold engine
the problem is that the chain over time stretches, due to the heat cycles and wear and tear..
a normal tensioner , will just keep pushing at the chain
while with a mechanical one , the chain will stop tensioning around the sprocket , because the tensioner does not move
hence the very frequent checkups required
