H.G.P.'s Avatar
What are "Solid timing chain tensioners"?
I have not seen these advertised much? Are these widely used?
Thank you.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-05-2004, 11:37 PM
Gon fix it with me hammer
svandamme's Avatar
never heard of that term , maybe they mean the racing mechanical variant , i had those in my engine when i bought it :
right
left one compared to the hydraulic one i just installed
Stijn Vandamme
BIMDIESELBMW116D2019
Old 12-06-2004, 01:47 AM
solid tensioner
Wayne's rebuild and performance book suggests using them temporarily during re-builds, but I have seen them advertised as Bullit Tensoners for e permanent use as well.
How do you adjust the tension once they are fitted? Is there a screw which increases the tensioner as you turn onto the idler arm?
Alex
Old 12-06-2004, 09:36 AM
H.G.P.'s Avatar
I did a search on tensioners and they came up. I'll see if I can find the link.
1969 911 E Coupe
chuckw951's Avatar
Stomkiracing sells them for $65/pair
http://www.stomskiracing.com/products.html
Email Steven, stomracing@aol.com, he can tell you about them if your search through the forum doesn't help.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 12-06-2004, 09:41 AM
Super Moderator
cstreit's Avatar
It's a manual adjust. Some people use them in racing motors permanently, but they need to be adjusted often, and the motor has to be good and warm before you go anywhere so the engine expansion takes up the slack.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
H.G.P.'s Avatar
They are list here down the page:
http://www.mpdonline.com/porsche.htm#Solid%20Timing%20Chain%20Tensioners
1969 911 E Coupe
Old 12-06-2004, 09:43 AM
Grady Clay's Avatar
This is probably one from the early ‘70s.
I use it when adjusting cam timing.
Solid tensioners are OK for race engines where you replace
the chains, sprockets and jack shaft regularly.
For normal use they are a no-fail alternative but
unnecessarily stress and wear the valve train drive parts.
There is a tool that measures chain tension.
I’ll see if I can find the info.
Best,
Grady
Old 12-06-2004, 10:07 AM
H.G.P.'s Avatar
Best,
Grady
After dismanteling the chain housing/tensioners/housing parts, I could see visible areas where the chains ran into the housing (stretched chains? bad tensioners?).
Why would a solid tensioner stress and wear the valve train?
Thanks!
1969 911 E Coupe
Old 12-07-2004, 09:10 PM
svandamme's Avatar
Thanks!
they don't move... so if the engine changes dimensions ( hot - cold ) it doesn't change with it like spring or hydraulic tensioners do...
so you either have a chain that is to tight or to loose , depending on your engine temp...
Stijn Vandamme
Old 12-08-2004, 04:48 AM
tensioner tool
Grady,
Any luck finding out about the tool for measuring early tensioner tension?
Thanks,
Alex
Old 12-08-2004, 10:36 AM
H.G.P.'s Avatar
What about in-between?
And how does one know if a "regular" tensioner isn't adjusting under normal instances? ( The tensioner is never seen while driving)
1969 911 E Coupe
Old 12-08-2004, 09:27 PM
svandamme's Avatar
if you set it inbetween , then it will be off for both temps , but just right for a half warmed up engined
a regular tensioner will apply a certain pressure to the chain
it doesn't matter how hot or cold the engine is , the pressure will be similar .. more or less
the solid one , doesn't apply pressure at all, it's just set to a certain location, and that location will usually be in the way of the chain , causing a pressure... but if the chain is stretching ( heat or old age ) then the solid tensioner isn't doing anything to counter it
i think the logical way is to say a solid tensioner does not make the tension , its the chain that tensions around the tensioner
( i know , this is crappy tech terminology )
while a spring or hydraulic tensioner , tensions the chain , if the chain changes then the tensioner will tension more
the hydraulic tensioner has an even bigger advantage, because it has both a spring ... and oil pressure , the higher the more revs, the more pressure , the more the tensioner tensions the chain
i don't think the problem is setting it for hot or cold engine
the problem is that the chain over time stretches, due to the heat cycles and wear and tear..
a normal tensioner , will just keep pushing at the chain
while with a mechanical one , the chain will stop tensioning around the sprocket , because the tensioner does not move
hence the very frequent checkups required
Stijn Vandamme
Old 12-09-2004, 09:04 AM
