Somatic Negative Optimist
I agree. That's why I said snug the nuts good when the car is up and torque the nuts when the car is on the ground. Below explains it better although I wonder..........
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Porsche sent a technical bulletin out when the 17" cup wheel was introduced on the 964 range. Everyone was instructed to tighten the wheel nuts to the correct 130Nm torque with the wheels off the ground. The information given was that the bigger wheels would not be completely hub centric if vehicle weight was on the wheels until the nuts were torqued. So all the shops tighten the wheels when off the ground. Use of Porsche grease on the wheel studs and nut cones was requested too.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
218lb Lap Timer
OK great! Thanks fellas!
Jojo
Jojo '84 3.2 Carrera Coupe '00 Jeep Grand Cherokee LTD "If everything seems under control, you're just not going fast enough" -Mario Andretti |
