Chris Lovell's Avatar
Shrink wrap with moisture absorber?
I am considering wrapping the 911s (like boats in shrink wrap) with a bucket of "Dry Out" chemical dehumifier wrapped inside. Can anyone tell me why this is a bad idea or won't work to keep the car dry? I can't move to Santa Fe or drive the 911s in the snow very well (plowing stinks around here and salt is in use). So, the cars are tucked away for the winter and I would like to keep the condensation at bay.
Thanks.
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 12-10-2004, 05:23 PM
I put mine in a "car jacket" that came with desicant. This is my second year using it and it works great. Do a google search on car jacket.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 12-11-2004, 08:07 AM
abit off center
cgarr's Avatar
I would not wrap it tite like a boat. I have seen the plastic or whatever they make the stuff out of release something that lift and crack the paints on autos. A fabric type cover may be the best
cg
______________________
Craig
G2Performance
Old 12-11-2004, 09:20 AM
randywebb's Avatar
Many of those things use vinyl - it outgasses vinyl chloride which is really bad, and then that also turns into HCl - hydrochloric acid - also bad! This stuff is known to photographers who store negs and slides -- they won't use it and pay extra for a different type of plastic.
See the prev. threads on this - I think we decide you'd be ok with a vinyl "hoop tent" type one with a ventilating fan.
Or just use a flannel car cover, with a water shedding one over it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-11-2004, 11:40 AM
I am actually considering a blue poly tarp to "envelope the car" over a Noah cover. This would help keep the vermin out and, with some humidity absorber, pretty dry as well. Think there would be any outgassing or conversion with this setup? Thanks.
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 12-11-2004, 07:23 PM
randywebb's Avatar
Sure there will be outgassing - but not the kind you need to worry about - and it will be ventilated well. Don't think the crystals will work to reduce humidity - big volume and not really sealed.
Nothing beats a garage tho.
Old 12-11-2004, 07:58 PM
Thanks Randy and all. I'll give this a shot and let you know what happens.
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 12-11-2004, 08:11 PM
The Chef
Guest
Posts: n/a
LOL LOL LOL LOL
Old 12-12-2004, 12:35 AM
abit off center
cgarr's Avatar
I think they started putting warnings on those blue poly tarps because of the problems with cracking your paint, something like "not to be used for autos or painted surfaces"
cg
Craig
G2Performance
Old 12-12-2004, 05:14 AM
They do have that warning but I am assuming it is warning against the poly tarp making direct contact with the paint. In may case, the poly is over a car cover.
I am pretty sure this should be okay. Anyone have any experience with problems doing this poly tarp "sealing" technique?
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 12-12-2004, 02:31 PM
this is easier for $150
http://www.autosportcatalog.com/index.cfm?fa=p&pid=2400
1984 911 Euro Cabriolet
1988 928 S4 with Murf Supercharger S1
Old 12-12-2004, 06:47 PM
Yep. That's it exactly.
My poly tarp and clothes pin alternative is similar .. and way uglier.
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 12-12-2004, 08:36 PM
