-   -   Silly Question, but what do you all use for keyrings? (http://forums.pelicanparts.com/porsche-911-technical-forum/196115-silly-question-but-what-do-you-all-use-keyrings.html)
mmm 12-09-2004 09:50 AM
My 1989 Carrera 3.2 has those lighted keys, which have a pretty narrow keyring slot and are also pretty wide/thick. Going through my varous keyrings (you know, that collection of bare rings we all seem to somehow have), I'm having trouble finding one that's thin enough in profile to allow the key to rotate around on the key ring and yet big enough to handle all my other keys (i.e. home, mailbox, office, wheel locks, other car).
Any tricks to finding a decent key ring for the lighted Porsche keys?
Slant930 12-09-2004 09:53 AM
What I did was find a small ring of thinner wire from another keychain and put that around the ring of the crest keyring that I have. The thinner wire fits in the lighted key slot. Looks good to me.
Timothy
jpnovak 12-09-2004 09:55 AM
I don't have any key ring. Just the bare ignition keys. House, bicycle and daily driver keys are on a separate ring in my pocket.
mmm 12-09-2004 09:58 AM
I've thought about doing this, but am afraid I'd end up loosing keys this way, plus my 911 is my daily driver so it's handy to have all keys together.
Grady Clay 12-09-2004 10:29 AM
Porsche sells a wonderful key fob.
On the left is the one originally delivered with my first 911 in ’68.
On the right is the one currently available.
It will fit the large lighted keys and additionally your license,
credit cards, insurance certificate, and more.
Nice leather and very durable, I have used up four of
them in 35+ years.
http://forums.pelicanparts.com/uploa...1102620226.jpg
Best,
Grady
vash 12-09-2004 10:38 AM
my 911 key is alone. i just replaced my budwieser bottle opener with my new "walking man" coin/fob/johnnywalker club member ID mediallion. kinda ironic that both key fobs are alcohol related.
arerrac 12-09-2004 10:45 AM
Single lighted key with crest key fob w/o leather back. Uses a SMALL ring on the key to the fob. Not the standard size.
Took out the crappy bulb and replaced w/a white LED and 3 3V duracel flat batteries. It a flame thrower now.
Someone else on this board did the LED converson.
-Wade
kqw 12-09-2004 10:45 AM
Like Grady...I use the Porsche leather key pouch with ONLY the car key, wheel lock and 1 house key.
Too many keys can over time weaken the ignition mechanism.
Also, a pouch prevents holes in your pants pockets.
porschenut 12-09-2004 10:45 AM
I have a separate key ring for each car. Each ring has house, car, mailbox, etc. They hang on hooks next to the garage door and I just grab the one I want on the way out. I also have 2 spares of every key, in safe places. I don't have the lighted key head, but I used to use a loop of thick string instead of key rings. Something like that might work.
GettinHeadStuds 12-09-2004 10:56 AM
-Wade
Lol are you serious? An LED conversion for the Porsche crest key? Pretty cool , I'm going to look into that one... :D
Here's my keychain --yes it is from Tiffany & Co-- don't laugh. It may be "chicky" but my mother got it for me, sooo.
http://forums.pelicanparts.com/uploa...1102622099.jpg
TMH 12-09-2004 11:01 AM
I recall reading this some time back as well. Also, with a lot swinging around down there it can start making wear marks on the dash and knee pad.
Keep it minimal and light.
Tom
Porschekid962 12-09-2004 11:02 AM
Leather string from a baseball mitt. Comes in black and tan, cheap and wears nicely over time.
randywebb 12-09-2004 11:06 AM
I use a light wt. key ring! -- a short length of nylon with my house key and car key on it. Quite functional.
Rot 911 12-09-2004 11:26 AM
http://forums.pelicanparts.com/uploa...1102623627.jpg
Craig 930 RS 12-09-2004 11:37 AM
I give these away to my frequent customers. Had them made in Canada - land of minimal litigation :)
http://forums.pelicanparts.com/uploa...1102624625.jpg
911boost 12-09-2004 11:57 AM
I have one from Brookstone that you push on the back qand detach each serperate ring. I have the house/office/mail keys in it, and each one of my numerous car keys on the parts that can be easily added. I get in the car, detach everything but the key needed and away I go. When I get to wherever I am going, I just put the rings back together. Works slick.
I don't work for brookstone or anything, just like the key ring.
http://www.brookstone.com/shop/product.asp?product_code=360545&search_type=search &search_words=Key%20Rings&prodtemp=t1&cm_re=Result *R2C2*T
It is like this but does have the light.
Bill
kees 12-09-2004 01:27 PM
keyring
http://forums.pelicanparts.com/uploa...1102631038.jpg
http://forums.pelicanparts.com/uploa...1102631104.jpg
http://forums.pelicanparts.com/uploa...1102631172.jpg
http://forums.pelicanparts.com/uploa...1102631229.jpg
Bad quality pictures, but I love keyrings.
SmileWavy
Kees.
arerrac 12-09-2004 03:06 PM
re:the LED for lighted key heads
I took one of the many free LED key ring light that you get a trade shows and opened it up. (Radio Shack is good too)
The LED fits perfectly in the original bulb holder.
You will have to get 4 3v Duracell flat batteries (DL1216). Stack them together and tape around edges to hold in place. (They are smaller than the factory battery, but fit perfectly in the button. The tape keeps everything together)
Now all you have to do is get the power to the LED. The LED legs are specific for + and -. Figure out correct way to power LED.
Have on leg from the LED go to the original copper base contact for negative. Where the bottom of the original bulb contacted. Trim to fit. I soldered it. The bottom of the battery will contact when pressed just like the original.
For the other LED leg, I soldered a short braded copper wire (from an electric R/C car motor brush) to the LED leg (trimmed to fit) and just rest the other end of it on top of the battery. Made a circle for more contact area. When you put it all together, the pressure from the spring keeps everything in place.
Like I said, it's a FLAME THROWER.
I'm a SLR guy so no digital for pics. If you need any help, just ask.
-Wade
KobaltBlau 12-09-2004 03:55 PM
http://forums.pelicanparts.com/uploa...1102640126.jpg
pwd72s 12-09-2004 04:45 PM
Again thinking of buying a digital camera. A pouch like the one on the left in Grady's pic stays in the house. It contains the original keys that came with the car..except for the one I use. It's "fob" is a 1972 Porsche calendar coin, a small split ring through it's drilled hole, which when hooked to a keychain sized split ring, makes the coin ride flat on the kneepad. To keep the coin from scratching the kneepad? Some old shoe tongue leather, black, contact cemented in place. The "heads" image of the 1972 calendar coin? 917-10 Turbo...
N11Porsche 12-09-2004 04:56 PM
332 people have read "The Keyring" post and 19 have actually had a comment on key rings:eek:
SmileWavy
Jack Olsen 12-09-2004 04:59 PM
I have a lighted Porsche key with the black plastic top with a silver crest on my regular keychain. But for 99% of my 911 driving, I use a cheap steel Audi/Porsche key with no fob at all. The advantage of the single keu is that it doesn't have anything to rattle or flap around on it, and it won't stress the switch.
no substitute 12-09-2004 05:01 PM
Anything with Tiffany and Co. on it is always cool, and not chicky at all. I just might have to gets me one.
pwd72s 12-09-2004 05:06 PM
SmileWavy
Probably intimidated...few would admit to being as anal about their cars as we who are fanatic enough to give thought to the key ring used... I would like to give an "Amen" to the suggestion that you NOT hang too much weight on a keyring. I used to carry too many keys on a single ring in my work pickup..store keys, lock keys, safe keys, gate keys, the list went on. The entire mess was at least 25 keys, and weighed too much. One day I found myself in a freeway rest area unable to put the ignition key back in the lock....A nice guy tow truck operator got me going again with no actual tow charges by using a pick that allowed me to slip the key in the ignition. I've paid attention to key chain weight since.
Zeke 12-09-2004 05:08 PM
I have had this in my pocket for 40 years. That's right, I picked it up off the ground when I went to work at a Corvette and Jag XKE salvage yard at age 19.
It WILL NOT break and has been polished by use. You know what it is and they're tough.
http://forums.pelicanparts.com/uploa...1102644473.jpg
Porschekid962 12-09-2004 05:41 PM
May the force be with you!
Master Yoda accompanies the Pcar everywhere!http://forums.pelicanparts.com/uploa...1102646462.jpg
msterling 12-09-2004 06:50 PM
This is my P-Fob. I think it might be OEM.http://forums.pelicanparts.com/uploa...1102650590.jpg
creaturecat 12-09-2004 06:53 PM
van Gogh for me:
http://forums.pelicanparts.com/uploa...1102650711.jpg
bell 12-09-2004 07:19 PM
http://forums.pelicanparts.com/uploa...1102652343.jpg
KobaltBlau 12-09-2004 07:21 PM
I vote or Milt's!
cnielsen 12-09-2004 07:50 PM
http://forums.pelicanparts.com/uploa...1102654214.jpg
Rufblackbird 12-09-2004 11:31 PM
I love keychains...used to collect them, but not anymore. I've always kept weight of keys in the ignition a minimum, after hearing other people's testimony.
Here's mine (yes...the wheel spins)http://forums.pelicanparts.com/uploa...1102667512.jpg
wente 12-10-2004 12:04 AM
one ignition key, and a very lightweight alarm fob. I've worn out ignition locks in the past with the vibrating weight. not going to repeat that mistake on this car!
fiminod 12-10-2004 10:23 AM
who needs a key fob when you have a starter button with master switch!?
asphaltgambler 12-10-2004 11:01 AM
A hand-stitched leather key fob from Porsche, with the gold Porsche crest inlaid. Now Buffy, pass me another muffin because I'm late for for my sailboating lessons.
}{arlequin 12-10-2004 12:08 PM
I am also guilty of having a Tiffany keyring. No pics (computer still down) but it looks like an elongated tear drop that's curved into a hoop. I needed something small and simple to hold my motorcycle and its lock keys together. (You really don't want much flapping around a bike ignition) Once the bike was stolen it's the only thing that I have left of it :(
Now for the same reason it holds the P-car key and the key to the quick release.
It's silver so it gets beat up, scratched, and dull rather quickly, which makes it look even less "chicky"
89turbocabmike 12-10-2004 04:38 PM
I'd like to have no key ring!
I've been driving a few Cadilllac XLR's and Lexi....at work, no choice;) All you need is the remote fob in your pocket. Walk up to the car, doors are automatically unlocked. Get in and push the start button and off you go. Hit the start button to shut off. Walk away from car and car locks.
I can't wait for this to come to the aftermarket.
wicked9 12-10-2004 06:46 PM
What the heck, Time to dust it off again anyway.http://forums.pelicanparts.com/uploa...1102736795.jpg
Noel 12-10-2004 07:14 PM
Bare key for me.
}{arlequin 03-07-2005 11:39 PM
catching up on some older threads....
http://forums.pelicanparts.com/uploa...1110271152.jpg
