H.G.P.'s Avatar
How's it possible to tell if a part has been either bead-blasted or walnut blasted?
How to tell the difference between the two?
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-09-2004, 08:04 PM
Zeke's Avatar
I think it would depend on what kind of part....
Old 12-09-2004, 08:08 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
mmmmmm no idea. glass bead media comes in different grit sizes, as far as shells who knows.
would it be a big difference to you if it was one or the other?
74 911s neverending story. two feet and a jetta for now.
Old 12-09-2004, 08:23 PM
H.G.P.'s Avatar
Yes, I understand that pistons should not be bead-blasted in the ring land. So in evaluating a used piston that appearance is good, how would one make sure it had not been bead-blasted?
1969 911 E Coupe
Old 12-09-2004, 09:00 PM
wow, thats a big diff from glass media blastin. i just went over my alu. bike frame with the glass blaster at shool and it has a much more uniform, slightly shiny look to it.
Old 12-09-2004, 10:22 PM
H.G.P.'s Avatar
Is there a texture difference that can be felt to the touch also?
1969 911 E Coupe
Old 12-09-2004, 10:45 PM
Glass beads will leave a surface finish not too different from that of frosted glass in texture (smoother perhaps), whereas walnut blasting should leave the surface texture near to original.
Regards!
Willem Fick
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 12-10-2004, 03:35 AM
