LinkBack | Thread Tools | Rate Thread |
What kind of damage can a loose (not broken) timing chain can cause?
I bought new chains, so my old chains I guess I just throw away, but just curious what damage a loose chain can cause, and the symptoms of a loose chain while driving.
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
A loose timing chain could jump a tooth on the camshaft sprocket , and that could cause enough damage to require open wallet surgery.
Symptoms of a loose timing chain will be a rattle at about 1500 rpm. The usual cause of a loose chain is the tensioner failing.
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Another way to tell if a timing chain is warn is by putting a wrench on the crank and turning it slowly while viewing the distributor rotor. Reverse the direction and note how many degrees the crank moves until the roto begins to move. I'm not sure of the tolerance but more than a few degrees can't be good.
Bill 90C2 |
Bill,
This test will tell you nothing about the chains. The distributor is driven by a gear on the crankshaft. The test you describe will only tell you the condition of the gears on the crankshaft and at the bottom of the distributor. -Andy
72 Carrera RS replica, Spec 911 racer |
Andy
You're correct, then I was thinking after I posted above that even if the distributor was driven as I was thinking (i.e. I really wasn't thinking) and there was slack in the chains it would be taken up by the chain tensioners. Disregard my earlier post it is totally incorrect. Sorry for the confusion Bill 90C2 |
Quick search for "chain tensioner catastrophic failure" led me to
this thread, which really answers your question nicely. Cheers, Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Don't turn your engine backward!!!!!!
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
