-   -   Sway Bars Question (http://forums.pelicanparts.com/porsche-911-technical-forum/196680-sway-bars-question.html)
ubiquity0 12-13-2004 10:16 AM
Sway Bars Question
I've seen conflicting info in the archives-
Will sway bars from a late G50 Carrera simply bolt-up to my SC? I think the 86 was the first year of the thicker bars, but were the rear bars changed for the g50 transmission?
magilla 12-13-2004 10:47 AM
Yes, I have done this to mine, and I know there are others here who have also. The hump in the rear bar is a little bigger (and will hang down a little), but it fits without problems.
v9ff 12-13-2004 11:40 AM
For what it's worth, I have 87 bars on my 84 and they fit great!
Az911 12-13-2004 01:04 PM
As other have said yes they fit fine. Also they are one of the best bang for the buck suspension upgrades you can make.
ubiquity0 12-13-2004 01:08 PM
Thanks guys. I'm assuming I just need the correct 86-89 bushings to fit these to my stock SC brackets?
ubiquity0 01-11-2005 04:16 PM
Found a set of these w/ decent looking rubber bushings & brackets :)
Jeff Alton 01-11-2005 04:23 PM
Brackets are the same, bushings are different.
Jeff
