Sway Bars Question
I've seen conflicting info in the archives-
Will sway bars from a late G50 Carrera simply bolt-up to my SC? I think the 86 was the first year of the thicker bars, but were the rear bars changed for the g50 transmission?
Old 12-13-2004, 10:16 AM
magilla's Avatar
Yes, I have done this to mine, and I know there are others here who have also. The hump in the rear bar is a little bigger (and will hang down a little), but it fits without problems.
'83 SC Coupe- Blk/Blk
'03 Daughter- 10fingers/10toes
Old 12-13-2004, 10:47 AM
v9ff's Avatar
For what it's worth, I have 87 bars on my 84 and they fit great!
Old 12-13-2004, 11:40 AM
Az911's Avatar
Send a message via AIM to Az911
As other have said yes they fit fine. Also they are one of the best bang for the buck suspension upgrades you can make.
72T RS look
96 993
Old 12-13-2004, 01:04 PM
Thanks guys. I'm assuming I just need the correct 86-89 bushings to fit these to my stock SC brackets?
Old 12-13-2004, 01:08 PM
Found a set of these w/ decent looking rubber bushings & brackets
Old 01-11-2005, 04:16 PM
Jeff Alton's Avatar
Brackets are the same, bushings are different.
Jeff
www.turn3autosport.com
Old 01-11-2005, 04:23 PM
