Plavan's Avatar
Polybronze install question
I just installed my Chuck's Polybronze bushings on the front. How much binding is too much? I shifted them foward, loosen, shift..etc and I cant get them to be the same (Left and right) also what are you guys torquing the bolts to? The arms do not drop under their own weight, are they supposed to? The passenger side moves very nicely but the driver side has a little more binding.
I am torquing the rear bolt (crossmember) to 45 lbs and the fronts to 25 lbs. Are these correct? If I loosen the front 2 bolts a tad the arm falls under its own weight.
They are all lubed up, just trying to get the final "free" play set.
Any suggestions?
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 12-19-2004, 01:28 PM
dickster's Avatar
hi
i am interested in this as i have some to install. i would think that the ideal would be for them to just about fall under their own weight.
Rich
'86 coupe
"there you are"
Old 12-19-2004, 01:42 PM
Jeff Alton's Avatar
They should fall under their own weight. I have put in 3 sests of these now and just use the factory torque spec.... just can't remember what that was. NO binding. On one car I did use Chucks new a-arm alighnmnent parts as well. I am sure Chuck will chime in here with some insight. Are they binding or is there just some resistance?? Has your car ever been "tweaked" in the front end?
Jeff
www.turn3autosport.com
Old 12-19-2004, 01:49 PM
Plavan's Avatar
It's has never been "tweaked". It may fix it's self once I have the factory torque specs. Once I loosen them they drop (watch your head ) I'm just not sure of the torque settings.
There is just some resistance no "real" binding. I'm happy with the passenger side- you barely put some weight on it and it moves freely. The drivers side moves freely with more effort. I just want them to drop under their own weight like yours.
Chad Plavan
Old 12-19-2004, 01:55 PM
Plavan's Avatar
Ok. I got the passenger side perfect. Drops under its own weight. Still messing with the Driver side.... Almost there.
Chad Plavan
Old 12-19-2004, 02:52 PM
Chuck Moreland's Avatar
Chad
What you are seeing is a lack of alignment between the front and rear mounts. eg. they are not on the same axis. The factory design aligns only in the horizontal plane, not in the vertical plane. Any tweaking of the front end (collision, pot holes, off track excursions, etc) can cause misalignment.
Factory mounts out of alignment
Low-Friction mounts, perfect alignment
Sounds like the passenger side is fine, and the driver side is slightly out of whack.
When everything is perfect the arms will drop under their own weight, slick as snot.
The Low-Friction Control Arm mounts solve the condition.
Chuck Moreland - elephantracing.com - vonnen.com
Old 12-19-2004, 04:08 PM
Plavan's Avatar
Yep, the passenger side is very good. The driver side is good. I'm not to concerned about it. They both are better than what I had before. I think after a little breakin the driver side will do the same.
Chad Plavan
Old 12-19-2004, 05:07 PM
Jeff Alton's Avatar
Did I mention you will love these?
Jeff
Old 12-19-2004, 09:44 PM
