North Coast Cab's Avatar
Carrera Rear Tow Hook Info
I'm looking for the screw-in type rear tow hook as well as the threaded block which is welded to the inside of the rear bumper on an '84 911. Does anyone have the Porsche factory part numbers for these?
John
1985.5 944 GTS
Old 12-24-2004, 01:23 PM
I've found some non-Porsche hardware that would work. I've got a 3/4" lifting eye and a small block of aluminum. I would tap the aluminum block and weld it to the inside of the bumper just like the factory one. I'm sure I could find a plug for times when it's not in use.
My question now is can I do the same thing on the front bumper? Will it support a pulling force like the rear bumper will? I've had the rear bumper off so I know how it is supported, but I haven't had the front one off.
John
1985.5 944 GTS
Old 12-24-2004, 04:56 PM
Still looking for part numbers.
John
1985.5 944 GTS
Old 12-26-2004, 11:22 AM
