-   -   3.2L to 3.5L - Part III (DYNO!!!) (http://forums.pelicanparts.com/porsche-911-technical-forum/198668-3-2l-3-5l-part-iii-dyno.html)
Carrera3.5L 12-27-2004 11:46 PM
Originally posted by rdane
Best of luck! Either way nice motor. I bet it is a hoot to drive. Ralph what is your car's weight?
Dane,
Weight is 2,880 lbs. with an absolute FULL tank of gas (i.e. can't get another drop in there). This was done in the summer before the motor came out.
With the new motor, the heavy heat exchangers were ditched in favor of lighter headers and the heater blower assembly and tubing was removed as well. I have the parts in the garage but haven't weighed them yet.
I'm sure someone here knows to the lb. how much less this is.;)
My Carrera is destined to be a civilized street car that my wife can drive on occasion and enjoy. IMO it is too nice to strip down any further. The only other thing that may be removed down the road is the air conditioning if/when it gives up the ghost.
Ralph
Wayne 962 12-28-2004 12:25 AM
280 is certainly possible, particularly with that displacement. What may hold you back are the somewhat mild cams you're running. That engine would scream with RSR pistons, an 'S' cam, and a Tec-3...
Don't bet the farm either on dyno results - they're all relative...
-Wayne
JeremyD 12-28-2004 04:44 AM
We are talking the conservative dyno at Vision, right? That's why I went low...
Mikkel 12-28-2004 05:51 AM
Just as important; how much torque will it produce?
Good luck with your lovely engine.
Carrera3.5L 12-28-2004 07:12 AM
-Wayne
Wayne, it has RSR pistons in it, one they work better for twin-ignition then the CIS/Motronic type and two, just in case I ever decide to take it out of the Carrera and stuff into a pre-76 chassis I would only really need to change the injection and install "S" or GE-60/80 cams. The bottom end is pretty much ready to go.
Motor is designed to pass smog (i.e. mild cams) here in California and the limitations that go along with it. A couple of hours taking the headers off and putting the stock system back on is not that big a deal. A cam and induction swap every 2 years would be a bigger deal (at least for me).
I've always said, if Steve Weiner ever gets CARB exemption in CA (but why would he go through the expense?) for his new ITB set-up with EFI, I am first in line.
Completely realize that dyno results can be taken with a grain of salt, I am really more interested in seeing the percentage gain since the motor was baselined on the same dyno. It's just kind of fun to play the guess the horsepower gain.
I will also be using Primedia Publishing's Dynojet 248C at a later date to compare the numbers that are received tomorrow.
Ralph
Carrera3.5L 12-29-2004 07:39 AM
off to the dyno, will try and post the results tonight! (good or bad)
Ralph
JeremyD 12-29-2004 07:47 AM
Good luck Ralph - I'm pulling for you...
911teo 12-29-2004 08:01 AM
Yeah... good luck!!! I can't wait to see the numbers. Must be quite exciting for you after all the work done!
jpahemi 12-29-2004 03:07 PM
Ralph:
Are you out there? The anticipation is killing me, please hurry!!
J.P.
efhughes3 12-29-2004 03:19 PM
Yeeeeeeeehaaaaaaaaaaa-can't wait!!
Carrera3.5L 12-29-2004 04:05 PM
I'm here guys, going to start a new thread.
Let's just say I've got a smile on my face!:D
Stay tuned!
Jcon 12-29-2004 04:21 PM
You're killin me where's the new thread??????
jpahemi 12-29-2004 04:43 PM
No, please, no more waiting, The humanity of it all; how can you you do this? ....and the numbers are???
insert chart here:
J.P.
Ps I wil not free Bertuzzi if you keep me waiting!!!!!!!!!
Shuie 12-29-2004 04:46 PM
Stay tuned!
tease.
link us when its up. I cant wait to see what this beast did.
Carrera3.5L 12-29-2004 05:32 PM
Can someone give me a hand and link to the other thread? I'm too computer illiterate to figure it out. It's all I can do just to turn the thing on.
Thanks!
MotoSook 12-29-2004 05:33 PM
Thanks!
http://forums.pelicanparts.com/porsche-911-technical-forum/198971-3-2l-3-5l-dyno-results.html
Carrera3.5L 12-29-2004 05:46 PM
Thanks Souk, I appreciate it!
Ralph
