-   -   Fuse or Relay? Or.....? (http://forums.pelicanparts.com/porsche-911-technical-forum/199001-fuse-relay.html)
jorian 12-29-2004 08:01 PM
My fresh air blower motor stopped working. Even though I recently replaced it. At the same time my cig lighter and rear defrost also stopped working. Could this be a single fuse (I checked and all fuses "look" ok) a relay, or is it a wildcat strike for better working conditions..........
fintstone 12-29-2004 09:59 PM
fuse #6 or the connection on either side of it.
jorian 12-29-2004 10:59 PM
Clarence,
Thanks very much for the info. Will try first thing in the am.
curiousone940 12-30-2004 05:24 AM
I have found that these ceramic type fuses can look just fine on visual examination...they might even check out OK with a meter...but, there can still be a continuity problem thru the fuse (on again, off again). As cheap as these fuses are, just replace the suspect fuse and you might find success. I've had this problem with turn signal and cruise control fuses on my '89.
jorian 12-30-2004 01:41 PM
Yep. Fuse LOOKED fine but the contact ends were black. Cleaned offending ends and Voila! now I can drive AND breathe heavily at the same time!
Thanks again for the posts.
fintstone 12-30-2004 06:20 PM
I love an easy fix! Good work and thanks for letting us know the outcome.
Jeff Alton 12-30-2004 08:04 PM
Thanks to those who contributed to this thread. You saved me some grief as this car was on its way over on monday!!!!;):D
Now instead of chasing electrical gremlins, I have to look at the sunroof:D :D Just kidding Jorian, I am glad this was an easy fix.
Please note I am making an attempt at humor!!
Cheers, Jeff
