Registered Cruiser
jorian's Avatar
Fuse or Relay? Or.....?
My fresh air blower motor stopped working. Even though I recently replaced it. At the same time my cig lighter and rear defrost also stopped working. Could this be a single fuse (I checked and all fuses "look" ok) a relay, or is it a wildcat strike for better working conditions..........
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 12-29-2004, 08:01 PM
Send a message via AIM to fintstone
fuse #6 or the connection on either side of it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-29-2004, 09:59 PM
Registered Cruiser
jorian's Avatar
Clarence,
Thanks very much for the info. Will try first thing in the am.
Old 12-29-2004, 10:59 PM
I have found that these ceramic type fuses can look just fine on visual examination...they might even check out OK with a meter...but, there can still be a continuity problem thru the fuse (on again, off again). As cheap as these fuses are, just replace the suspect fuse and you might find success. I've had this problem with turn signal and cruise control fuses on my '89.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 12-30-2004, 05:24 AM
Registered Cruiser
jorian's Avatar
Yep. Fuse LOOKED fine but the contact ends were black. Cleaned offending ends and Voila! now I can drive AND breathe heavily at the same time!
Thanks again for the posts.
Old 12-30-2004, 01:41 PM
I love an easy fix! Good work and thanks for letting us know the outcome.
Old 12-30-2004, 06:20 PM
Jeff Alton's Avatar
Thanks to those who contributed to this thread. You saved me some grief as this car was on its way over on monday!!!!
Now instead of chasing electrical gremlins, I have to look at the sunroof Just kidding Jorian, I am glad this was an easy fix.
Please note I am making an attempt at humor!!
Cheers, Jeff
www.turn3autosport.com
Old 12-30-2004, 08:04 PM
