porschett's Avatar
Help...Engine still runs with ignition off
Just replaced the plugs and distibutor. Wow, what a PIA just for the plugs. While I was at it, replaced the by-pass valve gasket, powder coated the fan and housing, replaced air pump filter, new wastegate, K27, 1bar spring
So anyways, unplugged the fuel pump relays and turned it over a few times to get oil in the turbo. Plugged back the relays and engine starts right up. At cold, it idled great. Rolled it out on an incline and let it warm up. All of a sudden, the engine cuts off. Tried to crank it over a few times and no go. Since the car is on a downward slope, I figured I roll it down on level ground. Sure enough it starts up. The low fuel light is on, so does this make sense? Try to take the car out for a quick spin, but it stutters really bad. Barely made it back to the garage. Tried to turn off the ignition, but the engine continues to runs for about 5 more sec or so. Switched it on again and it stutters. Tried reving to 3K and still stutters (like one plug short). I can hear some popping sound from the exhaust.
Every time I turn off the ignition, the engine continues to run for a few more sec.
Whew...So could the low fuel have anything to do with the fuel pump no building enough pressure causing the stutter? What's with the engine no cutting off?
Thanks.
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 12-29-2004, 08:12 PM
Jim Smolka's Avatar
Besides the obvious of adding more fuel...
That year 930's are designed to run for a second or so once the ignition is turned off.
Check the plug wires again and that the dizzy timing adj is secure.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 12-30-2004, 01:08 AM
the delayed ignition cut-off relay doing it's thing. get some gas too. the yellow relay on the rear electrical panel may not be seated. it cuts off the fuel pumps. easy to tip it a bit if the cover was off the panel.
206 637 4071
Old 12-30-2004, 07:54 AM
Zeke's Avatar
I'm no expert on turbo's, but I suggest some gas and double check your spark plug wires for position. It is very easy to switch a couple to the wrong cylinders. That would explain some of your symptoms.
Old 12-30-2004, 07:59 AM
porschett's Avatar
Thanks for all the advice gentlemen. I'll try them all and let you know what I find.
David Nguyen
Old 12-30-2004, 08:39 AM
73911guy's Avatar
I've had a bad diode on the alternator let the electrical system backfeed just enough to keep the engine running. Depressing the brake pedal and activating the rear lights was enough to stop the backfeed and shut the car off. The rebuilt alternator fixed the problem.
Jim
Old 12-30-2004, 08:59 AM
porschett's Avatar
Hi all,
Thanks for all the tips. I basically reseated the fuel pump relays and added more gas. Fortunately, all the symptoms disappeared.
Here's the obligatory engine bay pic after all the tune up.
David Nguyen
Old 12-30-2004, 07:17 PM
Jim Smolka's Avatar
Sweet!!!
It looks way too clean. Quick, take it to the nearest track and get some dirt on that thing
'81 SC 3.6 (Beast)
Old 12-31-2004, 04:20 AM
