Flip Up License Plate Frame
I've been searching for an old '70's style flip up license plate frame like those used when the gas cap was hidden behind the plate. I can't seem to find one anywhere. Any chance someone has one or knows where to find one?
I am finalizing my rear bumper convert, aka 89911, and I have moved the tow hook receiver to go under the rear license plate. The plate bolts will now house LED lights to illuminate the plate so I don't want to have to remove the plate everytime I head to the track. Also, I've got tons of pictures I will post when the project is complete. John
1985.5 944 GTS |
Might want to check JC Whitney or maybe some other outfit that sells parts for 70's muscle cars. Maybe like Year One. Just a guess.
Tim 1983 930 w/ goodies |
John,
You might try a junk yard that has older cars. I'm sure with enough sanding and fresh paint, it will be worthy of being attached to the 911.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Bird. It's the word...
I rigged up a central locking solenoid to push up my rear number-plate on my old R1 bike
I had a button on the bar that whenever I passed a speed camera I could lift the plate for "safety".
John Forcier Current: 68L 2.0 Hotrod - build underway |
Make Bruins Great Again
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
While you're back behind the bumper maybe some oil squirters and nails to drop behind you in a chase?
1967 912 2.7 1977 MGB (bright yellow) 1985 Honda Spree Moped (great for towing rollerbladers) A flute without holes, is not a flute. A donut without a hole, is a Danish. |
one of gods prototypes
john......mid 80's cutlass' and monte carlos has the spring loaded rear flip plate frame, junk yard may be your best bet.
any local yard will have these hoopties
Brought to you by Carl's Jr. |
Every custom sport truck place in the world should have one of these.
