Home of the Whopper
73T right blinker not working
Help!
I am going crazy trying to figure this out. My right side blinker does not work. The bulbs are good and the fuse is good. When I switch the right blinker on, both blinker indicators flash inside, but nothing outside. I am not getting any power to the fuse, so I traced the wire back to the light switch. No power there, so I went to the blinker switch.
When I switch the right blinker on, I have continuity between the grey and the grey/red wire. But I have no voltage at the grey wire. If I switch my left blinker on, I have voltage at the grey wire. I am confused. The way I am interpreting the wiring diagram, I should have voltage at the grey wire whenever the ignition switch is on, regardless which blinker is switched on.
My first thought was a ground issue at the light housing. But if the driving lights work the ground should be ok, right? Plus when I tried to measure voltage, I used the same ground for the right and left side. The left side was fine, but not the right.
Please help!
Thanks!
BK
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 12-30-2004, 05:16 PM
randywebb's Avatar
tabs bent that bulb nipples seat against?
search on turn signal + my name for some threads
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-30-2004, 10:12 PM
randywebb's Avatar
other thoughts - corroded fuse bayonet bases; bad gnds ----> that are not so bad that big amps won't flow but are bad for a small amp signal....
Old 12-30-2004, 10:13 PM
