Brother's Avatar
ABS Plastic
Some of you guys mentioned working with ABS before.
So, How do you do it?
Where is a good place to learn if you don't want to share the short or long version here?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 01-08-2005, 07:37 PM
one of gods prototypes
bell's Avatar
what are you making out of abs?
Brought to you by Carl's Jr.
Old 01-08-2005, 08:14 PM
Administrator
Jack Olsen's Avatar
What are you looking to do with it?
Old 01-08-2005, 08:15 PM
Brother's Avatar
Saw a post by Wil Ferch about making a oil cooler scoop out of ABS. I thought that sounded pretty cool but I didn't want to hijack the other thread.
Something like that or maybe other little pieces.
Paul
1972 914 - Sold
Old 01-08-2005, 08:20 PM
ABS is very formable with heat. For simple stuff, you can heat it with a heat gun and form it to your heart's desire. You could probably also heat-form it over a simple mold.
Old 01-08-2005, 08:46 PM
Brother's Avatar
Are we talking regular hairdryer or a real heatgun?
Paul
1972 914 - Sold
Old 01-08-2005, 08:51 PM
A real heat gun.
Old 01-08-2005, 09:06 PM
Diss Member
Quicksilver's Avatar
I used to have a link to a site where a guy showed how he made a vacuum forming rig using a Coleman electric grill turned upside down for a heat source and a couple large cookie sheets (the type with a raised edge). He drilled small holes in one of the cookie sheets and sealed the lips of the two sheets together. He hooked a shopvac up to the chamber formed by the two sheets to get a vacuum source.
The ABS sheet was clamped to a frame below the electric BBQ and he said the basic technique was to turn it on and when the ABS started to sag you simply lower it down over the mold until you have a nicely formed part and then turn the BBQ off.
Seemed pretty simple but you need to build a bit of a contraption.
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-09-2005, 01:05 AM
Brother:
Just saw my name get referenced here....and to be clear on my other post....the roofing vent pipe flashing I used wasn't reshaped with heat....I simply cut away the unused material to get the end-result I wanted. No heat or plastic reforming required. Sorry if I wasn't clear or if I misinformed you.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-09-2005, 07:22 PM
Brother's Avatar
Originally posted by Wil Ferch
Brother:
Wil
Picture please if you have the time.
Paul
1972 914 - Sold
Old 01-10-2005, 11:43 AM
Certified Pre-Owned
BGCarrera32's Avatar
Originally posted by Quicksilver
...a guy showed how he made a vacuum forming rig using a Coleman electric grill turned upside down for a heat source and a couple large cookie sheets.
Was it this guy?
'84 Carrera Coupe
Old 01-10-2005, 12:24 PM
Vacuum molding table planes:
http://www.halloweenfear.com/vacuumformintro.html
http://members.aol.com/GCGassaway/vacuform.htm
Warren & Ron, may you rest in Peace.
Old 01-10-2005, 01:13 PM
