-   -   I need a good switching!.... (http://forums.pelicanparts.com/porsche-911-technical-forum/199433-i-need-good-switching.html)
fred cook 01-01-2005 05:01 PM
Actually, I need a toggle switch that will mount thru the dash in a 911 SC. All of the toggles that I have been able to find have a threaded nose that is about 1/2" long and I need one that has a threaded length of about 3/4" long. Any and all leads, ideas or suggestions would be appreciated!
Fred Cook
'80 911SC coupe
Oldporsche 01-01-2005 09:26 PM
Fred,
I have seen long ones like you are seeking. I believe that it was in some military gear.
I might try an electrical supply house or Graingers.
I also would repost this thread. There are several posters that work as technical buyers that probably haven't seen your request.
Good luck,
David Duffield
banjomike 01-01-2005 10:10 PM
These guys might be able to help. It might be easier to just call them instead of trying to browse the inventory on the website.
http://www.electronicplus.com/
RoninLB 01-01-2005 10:12 PM
how large an amp draw on the sw?
fred cook 01-02-2005 05:04 AM
Long Thread Switch....
Thanks for the feedback, everyone.
The switch in question will only be used as a manual trip for an oil cooler fan relay. The amperage that it will have to handle will be very minimal. I want to install it in an SC dash just to the right of the steering column. There is a covered hole for some sort of switch in that location. The metal backing is already drilled with a 1/2" hole and the cover material is a soft foam.
Fred Cook
'80 911SC coupe
RoninLB 01-02-2005 05:59 AM
Re: Long Thread Switch....
the hole is for a stock P sw.
Mike Feinstein 01-02-2005 07:10 AM
Fred,
I wired mine up using the stock foglight switch. If your car has foglights, might be worth ditching them to keep the dash clean. If not, perhaps you can get a factory foglight switch from a later model. That way it would not look as aftermarket.
Wil Ferch 01-02-2005 06:42 PM
Why not use the location between thw left two gauges....square hole is aleady in-place ( covered by vinyl) used for the rear wipers for cars that have them. All cars have the "hole". I found a small, lit switch at NAPA that fits perfectly...choice of red, blue or amber. Used amber. Located right next to the oil gauges so it's also at the right "spot"...
Wil
fred cook 01-04-2005 03:47 PM
I'd rather switch than fight.....
Thanks to everyone for the tips and suggestions. After spending most of a day running around the Atlanta area looking for a toggle switch with a longer than normal threaded section (with no luck!) I went to a small hardware store here in South Georgia and found what I was looking for! So I now have a cooling fan on the fender mounted Setrab oil cooler that is thermostatically controlled and has a manual overide! I love it when a plan comes together! Now, on to installing the Pro Cooler that Santa left under the Christmas tree. We (both me and the engine) are going to be cooler next summer!
Fred Cook
'80 911SC coupe
