how to unglue rear view mirror
I improperly positioned the mount for the mirror on the w/s. Does anybody know how to unglue it so that it may be repositioned? Help Thanks
77 930 gone, but not forgotten
69 911T 3.0 lots of goodies
Old 01-02-2005, 08:45 PM
Autobahn Garage
A rasor blade, VERY carefully work it around all the sides. TAKE YOUR TIME don't rush it or you will break a chunk out of your windshield
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 01-02-2005, 08:54 PM
Makes sense, thanks tab.
Robert
Old 01-02-2005, 09:00 PM
I've used a heat gun on both the outside and inside patch area to soften the glue. I did it gently to avoid cracking the shield.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-02-2005, 11:28 PM
You guys have no idea.
Put on a crash helmet and give it a light tap with your head. Guaranteed to pop off - no fuss - no mess.
Worked for me about 3 times so far.......
Audi B7 S4
Old 01-03-2005, 04:28 AM
TMH TMH is offline
TMH's Avatar
I just did this on the track car as the rear view mirror on the windshield is useless with the roll bar in place.
Some have more patience than I, but I could get nowhere using a single edge razor blade. I ended up using a razor saw, and attacking the "button" on the windshield from various sides alternatively.
I think it took me about 15 minutes before the glued spot was so small that the button just popped off. Then I cleaned off the adhesive residue with a single edge razor blade. Can't tell the button was ever there.
Here is a link to the razor saws I am talking about:
http://www.stockade-supply.com/cat-tools/razorsaw.html
Good luck,
Tom
Ain't life grand?
Old 01-03-2005, 07:00 AM
