-   -   Need help re-connecting turn signal light (http://forums.pelicanparts.com/porsche-911-technical-forum/199497-need-help-re-connecting-turn-signal-light.html)
jakermc 01-02-2005 09:24 AM
I've nearly completed the installation of fiberglass RSR bumpers in place of the stock bumpers, but I have forgotten how the wiring works for the turn signals.
Below is a picture of the light bucket with the wires pulled through. The 5 spade connectors are labeled as follows:
1) Black and white
2) White wire that is pigtailed to brown wire
3) Brown wire
4) White wire with red stripe
5) White wire pigtailed to #4
The bucket itself has two spade connectors on the side pictured. These same spade connectors are also accessable on the other side, towards the inside of the car (not pictured). The light cover with bulbs also has two spade connectors.
Can someone help me match the numbered wires to the proper locations?
Thanks.
http://forums.pelicanparts.com/uploa...1104686663.jpg
jakermc 01-02-2005 05:19 PM
A bump so I can finish tomorrow .... :)
blue82coupe 01-02-2005 06:04 PM
jakermc.The 2 white wires ( 1 with a brown or ground attached) go to 2 lone terminals at the side of the "plastic" housing. The brown wire attaches to the back of the reflecter housing.The blk / white wire to the top of reflecter housing. The gray/ red goes to bottom of the reflecter housing.The gray/ red also has a white wire attached.Dan
jakermc 01-03-2005 07:15 AM
It worked. Thanks!
