jakermc's Avatar
Need help re-connecting turn signal light
I've nearly completed the installation of fiberglass RSR bumpers in place of the stock bumpers, but I have forgotten how the wiring works for the turn signals.
Below is a picture of the light bucket with the wires pulled through. The 5 spade connectors are labeled as follows:
1) Black and white
2) White wire that is pigtailed to brown wire
3) Brown wire
4) White wire with red stripe
5) White wire pigtailed to #4
The bucket itself has two spade connectors on the side pictured. These same spade connectors are also accessable on the other side, towards the inside of the car (not pictured). The light cover with bulbs also has two spade connectors.
Can someone help me match the numbered wires to the proper locations?
Thanks.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 01-02-2005, 09:24 AM
jakermc's Avatar
A bump so I can finish tomorrow ....
2003 Ferrari 575M
Old 01-02-2005, 05:19 PM
blue82coupe's Avatar
jakermc.The 2 white wires ( 1 with a brown or ground attached) go to 2 lone terminals at the side of the "plastic" housing. The brown wire attaches to the back of the reflecter housing.The blk / white wire to the top of reflecter housing. The gray/ red goes to bottom of the reflecter housing.The gray/ red also has a white wire attached.Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 01-02-2005, 06:04 PM
jakermc's Avatar
It worked. Thanks!
2003 Ferrari 575M
Old 01-03-2005, 07:15 AM
